Thread: DigitalFX 4.0
  1. #2071
    Jan 2008
    Thanks John, I did see that somewhere else in the help, well the hidden spots to change visualizations etc but didn't realise it was layout dependent, which is where I was gong wrong.
    Am I right in saying it is only in 3D logo and logo with compass layout that the visualization works?
    Thanks again
  2. #2072
    Aug 2008
    The installer locks up at 22% on the file FixFlash.exe.... Any idea how to fix it?
    Edit- Sorry, jumped the gun on this post.. A simple reboot fixed this strange problem. Kudos on the release
  3. #2073
    Low Bitrate overlander's Avatar
    Feb 2008
    In my attempt to follow the help file on installing CDrip, I have interpreted the following. Can someone confirm that this change to the cdrip line in exectbl.ini should get cdrip to work given a working aspi layer?
    "PS","RUNQ;$SKINPATH$Scripts\StopSong.exe||SETVAR; QUOTES;"||SETVARBYCODE;ListURL;CLTEXT||RUN;$skinpa th$scripts\playsong.exe|$QUOTES$$ListURL$$QUOTES$"
    "LockScreen","menu;screenlock.skin"
    "DAYLIGHT","Load;Daytime.skin;Daylight;$SkinPath$\ Scripts\Daylight.exe;Daylight"
    "CNN","RUNQ;$SkinPath$Scripts\CNN-News\CNN-News.exe||Load;CNN_News.skin"
    "LoadLyrics","Load;Lyrics_Display.skin||GetLyr ics"
    "ir","load;Internet_Radio.skin"
    "CDRIP","LOAD;cdrip.skin;RRCDRIP;RUNQ;C:\Progr am Files\RoadRunner\CDRip\CDRip.exe"
    "PluginManager","Menu;Plugins_Manager.skin||Run;$s kinpath$Scripts\PluginManager.exe"
    and further, I have added the referred lines to the end of the exectbl.ini file:
    "CloseGamma","SENDMSG;DFXSdr_Rcvr;close"
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    Am I interpreting this correctly? If not, can someone who has cdrip working with DFX 4.0 share their exectbl.ini file with me? I'm desperate, and waiting to start ripping my library into my new carpc. I have audiograbber, and it is working correctly in aspi mode (despite the error message I still get "aspi32 not installed correctly")
  4. #2074
    Jun 2006
    ok I'm going to show my ignorance with computers a little :-) I'm running a m10000II with 512k ram. I'm currently getting 30-40% cpu usage. I've read all the tips and what nots to help. I've been running the updated flash9 and now I've noticed that when I open the gauges screen I'm pegging out at 100%. My question is if I increase my ram to 1g will it make a difference on cpu usage ? Before even when I would use visu I run around 70-80% .. It would flucuate
    Mini Sumo Was Here
  5. #2075
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Mini Sumo View Post
    Mini Sumo Was Here
    I am not sure what tips you read and haven't read, but have a look HERE.
    number 5, 6 and 10 are the ones to look at. I think you may have missed that FAQ, as number 6 will fix your visualizations, and take it down to around 15-20% CPU usage.
    My Fiero Build Thread
  6. #2076
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #2077
    Jul 2008
    Myweather.xml in french
    Hi,
    Someone can tell me if it's simple to modify the RR script (or parameter ) to have the myweather.xml in other language (french for example... ;o) ?
    Other thing, when i change the coordinate for the live view, i have the right map, but the radar seem to work only in USA, someone have a solution ? there is a french website of wheather channel, but i dont found the source of the swf file,and the map don't seem to be dynamic. if someone can help me... http://fr.weather.com/mapRoom/mapRoom
    Thanks and bye
  8. #2078
    Jan 2007
    San Francisco
    Quote Originally Posted by utd09bry View Post
    edit: out of mere curiosity.. do you currently have RR set to read GPS info (i.e. an Xport setup) ?
    Yes, I do. Why?
  9. #2079
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by carputer1 View Post
    Good Catch!
  10. #2080
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by boriman View Post
    Yes, I do. Why?
    didn't know if you were just crashing because it was expecting GPS data but you weren't feeding it any
    carry-on
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
