can the vol goes up to a 100 mine is on 50
thanks got it
6 5 more to go
Damn, this thread is growing too fast! Checked it this morning, and now there are 3 more pages. I will try to keep up with the questions, if I misses something let me know.
GPS in the main menu. That would take some doing, as there is an application area at the top of the skin defined for the visualization. Only one application can be on any single skin at a time.
HD Radio switching between AM & FM: This is due to something with the hardware, or the way the plugin was written. Check the HDRadio thread, there is something you have to manually create and rename a text file or something, then the AM/FM Toggle will work.
Numbers instead of buttons: Somehow the font was uninstalled. The icons are now actually a font, and not graphics so the color can be changed.
Video menu bar not hiding. That is a new one to me! I have never seen it on any other skin than on the Video Player skin. Something is really screwy somewhere, and I have no idea where to look for it. Sorry....
Sirius and XM signal strength not showing correctly: Unfortunately I do not have either here, so I have no way of testing that one. If someone fixes it, please share the fix/code with me and I will make sure it is in the next release
Image viewer: It was installed with the skin and is in Road Runner/ImageViewer
You will need to open the imageviewer,ini and set the path to your images for them to show up. FOr more info on it check the help file.
I think so
Me either.
Huh? What did I miss?
I will be out of town.... well actually out of country, in Canada on business for a week or so. I'm not looking forward to the weather, I am told there is 2 feet of snow on the ground! I will have to dig and even see if I have a winter coat somewhere! I am not sure how much time I will have to check the forums, so if I appear to have deserted the questions, I will be back early next week and will try to answer any questions then.
On a final note, BlueZX3 and I talked for almost 5 hours last night working on his music database for Road Runner. He has done an amazing job with it, now I have to do my best to incorporate it into the skin, in an easy and user friendly way. There are just SO MANY options available, (Sorting, Searching, 10 Disk Changers, Virtual play lists, browsing modes, Ratings, all with a database that stores everything so it is lightning fast!) I could fill 2 screens with just buttons to take advantage of everything that it can do! If all goes well, this should, and hopefully will be available in the next release.
My Fiero Build Thread
You have to embedd the lyrics into the ID3v2 tags of ALL your mp3s. it's fun I know. This program actually does remarkably well. There is going to be some trickery involved into getting it to work.
Start here: Release Lyric Tagger
Then start here: http://www.mp3car.com/vbulletin/rr-s...eased-175.html
Posts 2612-2659 in the original DFX 2.0 thread, was the progress I had into getting the program to work correctly.
