Thread: DigitalFX 4.0
  1. #2111
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Which RoadRunner exe should we have?
    I'm trying to determine which RoadRunner.exe should we have? I have a few problems after the update to DFX4.
    1. The logo, spinning logo, playlist, etc. don't show up now. If I go back to date 12/13/07,the weather does not work. Also, I used Mitch's RoadRunnner.exe since it had updates for XM and HD but that one has the same problems too.
    EDIT - I had the wrong roadrunner.exe (found the correct one 5/8/08 and it works; however Mitch's version does not work)
    2. The Calendar (Rainlendar) does not work (blank). I moved the folder over from DFX3 to DFX4 but that did not make a difference.
    EDIT - There is a new Rainlendar version and you have to go to that thread to get this to work or you can just rename the button back to Calendar to use the old one.
    3. This may be a feature change, but TrafficCams pull up GoogleMaps. I liked the cameras setup, so I will try to change that back.
    EDIT - I will use the TrafficCams camera view and keep GoogleMaps like it is.
    Great Job John on this update....love the new features. BlueZX3 - great plugin man!
    Thanks for the help....
    Gee
  2. #2112
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by navputer View Post
    I'm trying to determine which RoadRunner.exe should we have? I have 5/8/8 but I have a few problems after the update to DFX4.
    There is still a button for "traffic cams" as opposed to "google traffic". If you go into utilities that is going to bring up Google Traffic. If you just use the provided menu button it is for Traffic Cams plugin, which you have to install yourself. Currently there is no menu button for Google Traffic, but it is easy to make one.
  3. #2113
    Jul 2008
    Quote Originally Posted by JohnWPB View Post
    Nice Find! I was looking for something for Europe to display the weather! I put together a little script to embed it into the skin.
    There is a WeatherEurope.ini file in the folder. In it you set your language, Continent, and Country. For instance for France, it would look like this:
    John, to check it, i need to wait your next full release ?
    or you put the modification somewhere ?
    many thanks
  4. #2114
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi
    Well i am from India so obviously the US ZIP codes dont work here.
    Nor do they show up on the Gauges page......
    Is it possible to replace those zip codes with the codes prevailing here....
    Also if this is possible can u help pls as how to go about it....
    thanks in advance
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  5. #2115
    Nov 2004
    St Louis
    John, another outstanding update!!!! This is one of the most stable, almost bugfree skins for RR. CUDOs to you and Blue. Got just about everything working. This skin is so featurepacked I need to figure out how to add pages cause I can't decide on all the stuff I want
    For those of you that also listen to FM , XM, and Sirius, I have some skin mods for DFX. I may have mentioned these for DFX2 and 3, but the thread is so long another time can't hurt. For radio controls from screens with next and previous buttons, replace NEXTTRACK/NEXT and PREVTRACK/PREV with RRNEXT and RRPREV, respectively. To get the radio preset to display outside the radio screens, globally replace TAGTITLE with TRACKNAME.
    I do need help from the RRCoders out there to help me figure out how to clear the ARTIST and ALBUM labels and whenever the radio is playing automatically replace them with RDSTEXT and RDSNAME. I was going to do it manually with
    Code:
    L20,525,85,255,29,#DFX1R#,#DFX1G#,#DFX1B#,23,#DFXFont#,"TAGALBUM>>sil_rdsps","LEFT"
    L21,91,82,359,36,#DFX1R#,#DFX1G#,#DFX1B#,23,#DFXFont#,"TAGARTIST>>sil_RDSText","SCROLL-LEFT"
    But realized there's already a button over the ARTIST label. So I have no idea how to automate this. There was discussion elsewhere about setting an RR variable for what audio source is current. Taking that info I'm sure we could come up with some exectbl.ini coding that could read that info whenever you change screens and update the artist and album fields when the radios are active. Something like:
    Code:
    "AUDIOCHECK","evaluate activeaudio;fm;byVARBYCODE;rdstext;ALBUMVAR;byvarcode;rdsname;ARTISTVAR
    and replace TAGALBUM and TAGARTIST throughout the skin with ALBUMVAR and ARTISTVAR. I just have no idea how to accomplish this.
  6. #2116
    May 2006
    Chicago
    I don't know if anyone posted this yet (I just saw the release of 4, so i am way behind on the thread) but be sure to backup you zips.dat file if you have the larger (more accurate) one because as it is, DFX 4 overwrites it with the old one.
    I am the stig's cousin.
  7. #2117
    May 2006
    Chicago
    Question: The wireless manager skin is not showing anything, or information is incomplete or incorrect, how do I fix this?
    Solution: you have to be using the windows wireless manager. Many WiFi cards come with their own software. Just uninstall the software, and only install the drivers for your card. You can try using add/remove programs to remove the manufacturer provided drivers. If all else fails, remove the wireless software from the manufacturer, and the wireless device in device manager, then unplug it. Plug it in, and windows will then prompt you for the drivers. Insert the CD and windows will install the drivers to enable the device. If the CD auto runs, and tries to install their software, just cancel it.
    I wanted to add something to this. I was having trouble with this working because I had renamed the wireless connection to WiFi. The wireless connection must be named "Wireless Network Connection" without quotes.
    Start > Control Panel > Network Connections
    Make sure the wireless network device is named "Wireless Network Connection"
  8. #2118
    Dec 2003
    Hi
    Well i am trying to modify the skin buttons with the "" DFX Menu Button Editor"" from the help file....It opens up the 3 pages but when i modify a buton with an icon (png)... and save ... nothing happens on the MAIN screen buttons.. ( It remains the same ) BLANK....
    Can some 1 pls help
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  9. #2119
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    This has been done globally throughout the skin now. As for the RDS info, that's a whole another story, and I haven't figured out a way to do that yet.
    Quote Originally Posted by lewcamino View Post
    This has been fixed, and the installer will not install the zips.dat if it already exists.
    My Fiero Build Thread
  10. #2120
    May 2006
    Chicago
    Did you add the larger zips.dat to the installer as well?
    I only ask because the original places me about 4 towns over and I am sure it is similar for others. Midwest... what can you do?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
