Thread: DigitalFX 4.0
  1. #2161
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by navputer View Post
    I had these same issues - See post 2111 (page 141).
    Thanks for the help. I downloaded the latest version of RR and will try it out later today. As for calender, I have not been able to find the latest version. If you don't mind, can you please post the direct link to the thread or Rainlendar itself ?
  2. #2162
    Newbie k1hog's Avatar
    Oct 2007
    I know is is some where, but can't fine where? When I go to gas prices, RR hangs, is there a fix?
    Johnnie
  3. #2163
    Jan 2008
    CD Changer Problem
    First, great skin, John! I created a disk in the disk changer. I used 5 cd's from one artist to make up the disk. When I start playing it, I go into playlist, sort playlist, and choose randomize. It works great, until I turn the truck off and then back on. The playlist still looks randomized, but it is playing the songs in the order they were put into the list. The song highlighted isn't what is playing. Any ideas of what's going on?
  4. #2164
    Constant Bitrate notion's Avatar
    May 2002
    San Diego, CA
    Zips.dat
    Is the zips.dat file a limited list? Can it be added to or updated from a 3rd party source?
    The reason I ask is that the guages and gas prices page keep reporting me as being in the next city over from where I live (bit of a problem when navigating to nearest gas stations). I was assuming that this is happening because that's the nearest zip code in the database to my GPS coords. I added the 1 minute update command to rr.ini but the Zip code doesn't seem to want to change even though GPS is working fine in iG4 and with the skin's GPS Speedometer, long, lat, height and satellites locked (all set up with XPort)
    I'm using a SirfStar 3 USB GPS unit
    Also, different tangent...
    Question: Why does album art flash at start of song then disappear?.
    Solution: You do not have Embedded album art in your MP3's. Go into the plugin manager in the skin settings, and turn off MP3Art.
    Does this mean that RR+DFX 4.0 displays embedded album art now? I guess it does, if so do I have to choose any IDTag specific settings to ensure they all show up?
    DFX 4 once again moves the bar up for Roadrunner, this skin looks fantastic and the embedded music DB is FRIGGIN' SWEET!!!!
    Thanks guys
    350z Roadster,
    Lilliput 7" touch, Opus 250w, 160gb, AMD3500+, 1gb ddr400, geforce 6500 pcie, SiRF Star 3, Wireless G, Sprint CDMA, Bluetooth, Creative iCam Pro, RR, iG 4, Digital FX 4.0
  5. #2165
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by notion View Post
    Yep, notepad.
    Record the coordinates of where you are, then open zips.dat in notepad then either find the city name you want to show when you are at those coordinates and edit it's coordinates OR find the coordinates and edit the city name (i don't remember exactly).
  6. #2166
    Apr 2008
    Looks Great!!!
  7. #2167
  8. #2168
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    I am getting an Autoit Error 'Script could not be found' or something. I'm @ work and can not remember the exact error. What is that error about? It happens when I switch back from Gauges, and sometimes when I switch to the main screen from any screen.
  9. #2169
    May 2002
    San Diego, CA
    Quote Originally Posted by Maddominican View Post
    I had the same problem, turned out my RR install was in a folder called 'Roadrunner' rather than 'Road Runner' so the pathing on the DFX4.0 installer had some problems installing everything in the right place, even if you change the install path in the DFX4.0 installer.
    I fixed mine by reinstalling RR to the correctly named 'Road Runner' folder and then reinstalling DFX4.0, this helped clear up some other little issues I had with Gas prices routing to IG4 also.
    350z Roadster,
  10. #2170
    Apr 2008
    Does the new rrgas version work now for this theme? What about weather?
    O yea, and the skin won't let me turn on music videos to my rear screens while driving, how can i disable that?
    EDIT: Knew I was forgetting something......in the Gauges portion, I got it running, but it's showing my speed to be ~20mph over what I'm driving at.....
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
