Thread: DigitalFX 4.0
  1. #2181
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Since this is open "open source" and a community of development I don't see why that would be out of line...?
  2. #2182
    Newbie riggs's Avatar
    Mar 2007
    UK
    Skin not displaying correctly - vertical bar in middle
    Quote Originally Posted by Ramanator View Post
    Also try opening up your rr.ini and chck to see if Fastmode is set to -1.
    Thanks Ramanator, I openned RRconfig and changed Fastmode from "ON" to "GDI" and this fixed it. The whole time I was testing I was changing fastmode as I didn't know it had this effect at the time.
    Had no other problems so far other than CPU usage at 40-50% on the main menu and 60-70% on the Gauges. This is after trying points 1-9 on http://www.mp3car.com/vbulletin/rr-f...ad-runner.html and tried the Flash fix that came with DFX4. I don't want to have to remove the Carputer in order to connect to the Internet at home and try point 10, so I'm going to see if I can download the Adobe Flash 9 installer exe later and reply with an update.
  3. #2183
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    @ Ramanator: Thanks! This is something I overlooked, and has been added to the FAQ's in post #2
    My Fiero Build Thread
  4. #2184
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    so maybe this has been answered, but i couldnt find it...
    im currently using mitchjs build of the 11/7 rr
    using DFX4
    whenever i select a folder to play, then append another folder to the current playlist, then go to sirius, hd, hibernate or anything like that and then go back to audio, i lose the playlist... just the orignal folder is there nothing else.
  5. #2185
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    ive been trying to figure out why i wasn't seeing any playlists in the manage playlist screen.
    i never needed the screen, but now i do since its the only way to add my entire collection (through searching and adding the search results).
    anyways, the fix was adding the playlist file types to the "Audio File Types" in RR Config (*.m3u, *.pls, etc).
    just thought i'd put that out there in case anyone else missed that, too. i never thought to do that
  6. #2186
    Nov 2007
    PA
    Anyone else having the problem with Elevation bar in gauges screen stopping at 2,400 Feet? Hate to ask again but it seems to me a lot of posts are being ignored these days.
  7. #2187
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Gauges Source Code for Altitude
    Quote Originally Posted by Dougw133 View Post
    The gauge I am using only goes up to 2,400 feet.... I never realized that, as I do live in Florida (The FLAT state) hahha I am only like 20 feet above sea level here.
    If someone knows SwishMax, and can increase the limit from 2400, that would be great! The gauge source code is avail IN THIS POST.
  8. #2188
    Jan 2007
    Ive been whipping my mp3 collection into shape after finding out that i needed all my cover art in the respective folders (they were are all embedded) and then embedding the lyrics (which i Kept in a common folder) for a few days now. (large library) Instead of asking a bunch of questions i searched my butt off and downloaded; av albumartfixer, mp3tagger, albumartfixer, minilyrics, evillyrics, lyrics3, lyric tagger, mediamonkey and toast and some others. Think I 'bout got it. Point is i test ran the hole show on my desktop, then laptop, and just got to putting it on the carputer.
    Ive cant figure out why the gamma slider has become non-responsive. slider part is anyway the 2 buttons work. just cant adjust it.a little help and or the rr.ini and rr config setting related to gamma would be appreciated. I am a novice user.
    I have the latest ver. of rr with the beta on top.
    Everything is superb with the skin, yet i have a request. i understand the lyrics need to be embedded for the lyric page in dfx4 to show them. is there a way to have the lyric page look at the common folder where common lyric programs and plugins cache their .txt and .lrc files?
  9. #2189
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by southtarnation View Post
    Ive cant figure out why the gamma slider has become non-responsive. slider part is anyway the 2 buttons work. just cant adjust it...
    I noticed that happens when i move the slider to a setting but then "quit" without applying the setting; from then on, the slider don't work unless the skin is restarted. If you hit "apply" all the time, it will work fine.
    It has nothing to do with rr.ini gamma setings.
    There is a bug report on it i believe.
  10. #2190
    Nov 2007
    PA
    Quote Originally Posted by JohnWPB View Post
    Got ya... Didn't know if that was the case or there was something wrong on my end. I'll look into it, thanks.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
