Page 22 of 557 FirstFirst ... 12131415161718192021222324252627282930313272122522 ... LastLast
Results 211 to 220 of 5570
Thread: DigitalFX 4.0
  1. #211
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by ding0 View Post
    As sure as a noobie can be!
    Here are the settings:
    OK. I'm confused with ur situation.
    Does the program open up in DFX? Does the program open up outside DFX?
    or is the program not finding your GPS coordinates? Have you split your GPS ports. To me, 18 seems to high for a GPS port. Try to keep everything below 10.
  2. #212
    Low Bitrate lor109's Avatar
    Mar 2004
    Quote Originally Posted by the_crooked_toe View Post
    I remember reading in the 2.5 thread somewhere that Com ports needed to be less than 10 to work with xport correctly.
  3. #213
    Low Bitrate jjnit's Avatar
    Feb 2007
    Wow - I've been out of the country for the last 6 months, away from my truck and this hobby, and have just pulled my truck out of the garage and decided to take a look at this forum.
    The last time I used this skin it was still at 2 - with only rumors of a 3.0 version. JohnWPB - this thing has progressed into a work of art! I hit you up with another donation - everybody else, if you're using this as your regular skin, you should really consider donating. That list of names seems awfully short to me after seeing what this last version looks like.
    Anyway -I've had no issues so far, but I'll be putting this through the wringer as I have a road trip this week from ATL down to Miami - plenty of time to get acquainted again.
  4. #214
    Jul 2006
    XM/Sirius Signal Strength
    Ok, I think I've got the signal meters sorted out, but I can't verify because I'm at work. Anyone want to try it out and let me know?
    Attached Files Attached Files
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  5. #215
    Feb 2008
    Outstandign Skin.... I've gotten nothing done at work, and my children felt neglected last night.
    You deserve mad Kudos ! ! !
    Thanks for being an enabler, and helping with my addiction
  6. #216
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by JohnWPB View Post
    On a final note, BlueZX3 and I talked for almost 5 hours last night working on his music database for Road Runner. He has done an amazing job with it, now I have to do my best to incorporate it into the skin, in an easy and user friendly way. There are just SO MANY options available, (Sorting, Searching, 10 Disk Changers, Virtual play lists, browsing modes, Ratings, all with a database that stores everything so it is lightning fast!) I could fill 2 screens with just buttons to take advantage of everything that it can do! If all goes well, this should, and hopefully will be available in the next release.
    Just you guys wait.... and you thought DFX 3.0 Couldn't possible get any better... If I get this kinda feedback from john about the media plugin, that in itself speaks of great things still to come!!
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #217
    Dec 2007
    Hmm.. task manager.. I can kill a process when viewing in task manager....
    but, in open windows, whenn click end task button, it just removes the name and the process still running...
    Can anyone confirm this?
  8. #218
    Jun 2007
    Confoosion setting in - getting frustrated
    I've been trying to get iGuidance 4.0 running on my desktop correctly using DFX 3.0 since John posted the link with partial success. It seems to run ok but the buttons: Toggle North - doesn't work at all; Zoom + & Zoom - work but only on about 1 click in 5.
    Below is a text file indicating the steps I took and the RR.ini file. Could someone PLEASE look this over and tell me what I've done wrong?
    Install Xport
    set ports to use = 8, 9 (Actual Port is 3)
    Install Roadrunner
    Install DFX 3.0
    RoadRunner settings (rr.ini):
    Code:
    [Player Setup]
    player=Winamp
    winamppath=C:\Program Files\Winamp\
    hidewinamp=true
    exitmute=true
    [General]
    voice=false
    disableinternat=true
    showicons=false
    showextensions=false
    hidemouse=false
    hidetaskbar=false
    hidedesktop=false
    hidedots=false
    gpstime=true
    gpsusadate=true
    exitmode=0
    dateformat=Short Date
    timeformat=Short Time
    locale=0
    screentype=16:9
    debugmode=false
    enableclipping=true
    nozoom=false
    usegestures=false
    leavemousealone=false
    closeapps=false
    fastmode=-1
    usedualmon=false
    soundcard=0
    screenlimit=10
    resolution=1680x1050x32x60
    mastervolmap=0
    hibernateaware=true
    forcehibernate=false
    hibernatereload=true
    usbsound=false
    browsertype=1
    browserpath=C:\Program Files\Internet Explorer\iexplore.exe
    usevoicecontrol=false
    usecar2pc=false
    fadeinvolume=true
    picspath=C:\TEMP\
    [Skins]
    skinpath=C:\Program Files\Road Runner\Skins\DigitalFX 3.0\
    nightskin=C:\Program Files\Road Runner\Skins\DigitalFX 3.0\
    transition=0
    background=C:\Program Files\Road Runner\skins\DigitalFX 3.0\DFXBACKGROUNDS\
    TransitionTime=0.2
    [Gamma]
    gammamode=3
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=1:00
    gammanighttime=1:00
    autogammamode=1
    autoskinmode=1
    [Preload Screens]
    [Music]
    musicpath=G:\Winamp Music\
    playlistpath=G:\Winamp Playlists\
    useid3=1
    showid3playlist=false
    showid3browse=false
    lazytag=false
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=false
    visuname=MilkDrop
    scrollmode=1
    circularlist=false
    groupnumbers=false
    resumemusic=0
    audiorepeat=false
    audioshuffle=false
    transparentvisu=false
    opacityvisu=40
    [Radio]
    radiomode=0
    allowallfreqs=false
    radioline=0
    userbds=false
    [XM]
    xmport=0
    xmline=0
    xmlineinplugin=false
    xmtype=0
    singleclickxm=false
    xmformat=%station% %artist%
    [SIRIUS]
    srport=0
    srline=0
    srlineinplugin=false
    singleclicksr=false
    srformat=%station% %artist%
    [Video]
    videopath=Click here to set path
    mpcpath=Click here to set path
    videoautohide=true
    videohidetime=4
    builtinvideo=true
    videoshuffle=false
    [TV]
    tvline=0
    [GPS]
    gpsmode=2
    mapmonkeypath=Click here to set path
    gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    gpsname=iGuidance
    overspeed=80
    gpsport=9
    mappointmap=1
    mapcountry=United States
    mapcity=Hilton Head Island, sc
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    [IG Native]
    ignative=true
    igautosw=false
    gpsonvoice=true
    pauseonvoice=false
    lastscreenswitchtime=0
    [Speed Att Vol]
    speedatt=false
    [Phidget]
    phidget1=0
    phidget2=0
    phidget3=0
    phidget4=0
    phidget5=0
    phidget6=0
    phidget7=0
    phidget8=0
    [4 Temps]
    tcomport=0
    tempscale=c
    temp1=c
    temp2=c
    temp3=c
    temp4=c
    [Volt Meter]
    vcomport=
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=Click here to set path
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=true
    standardphonebook=0
    phonebooksencoding=windows-1252
    [Weather]
    cityweather=Hilton Head Island, sc
    weatherunits=USA
    weatherdegress=º
    localdatacaptureinterval=0
    [Extra's]
    DSX Things Done (from the help file):
    - Open the skin folder/Scripts and find the AutoLaunch.ini file. Open it in notepad. Change the drive letter to your CD.DVD Drive. Now, when you insert a CD/DVD in the drive it will automatically play. When ejected, it will resume the song you were listing to, at the position it was at before you inserted the CD.
    In the skin folder. there is a folder named Support Files, "theme.ini". Place that in the root of your iGuidance directory (C:\Program Files\iNav\iGuidance\) to change the colors, road widths ect to mimic the look of Google maps. This is a much cleaner look, and does not look as "Cartoonish" as the default iGuidance colors and road widths.
    Run Roadrunner
  9. #219
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    see if you have the process cftmon.exe running in taskmanager, if you do kill it.
    EDIT*all of your sendkeys behave this way right? not just n, +, and - , does the keyboard work?
    Quote Originally Posted by lor109 View Post
    I think it's...com port needs to be less than 10 for Iguidance to work correctly
  10. #220
    Newbie Smitty0881's Avatar
    Sep 2006
    Upper Marlboro, Maryland
    Just loaded the skin and everything works perfect. No problems at all. Great job John. U da man
    -Smitty
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
