Thread: DigitalFX 4.0
  1. #2191
    May 2006
    Chicago
    Quote Originally Posted by treetop777 View Post
    Yep, notepad.
    Record the coordinates of where you are, then open zips.dat in notepad then either find the city name you want to show when you are at those coordinates and edit it's coordinates OR find the coordinates and edit the city name (i don't remember exactly).
    Don't do that...
    Here is the thread that addressed this issue. There is a newer, shinnyer zips.dat posted in that thread.
    http://www.mp3car.com/vbulletin/1123845-post18.html
    Replace the small zips.dat with this one.
    I am the stig's cousin.
  2. #2192
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi Guys,
    Well I am trying hard to get the BUTTON and ICON change...
    The Button ( text ) display changes BUT I AM NOT GETTING ANY ICONS ( its blank )
    Can some 1 pls help me as how do i go about it...
    I tried to create my own icons ( PNG format ) and also tried to replay from existing ones but still they dont sow up.....
    PLS guys help me out
    thanks
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  3. #2193
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by vicky_obee View Post
    Hi Guys,
    thanks
    See if you can do it manually. The last section in this post talk about how to display the icon.
    http://www.mp3car.com/vbulletin/1224017-post1359.html
  4. #2194
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Hi Guys,
    thanks
    I have check the btn edtr and see absolutly no probs with it... with RR open and changing one of the displayed main menu screen icons, as soon is i select any pic from any location and click open the icon changes to what i selected...
    maybe a screen cap of one of the btn's your trying to change showing the button properties window from the BE.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #2195
    May 2006
    Chicago
    I have a couple questions that I could not solve on my own.
    1. GPS Auto switch (iGuidance): I use the GPS skin with the music info across the top. When it auto switches for navigation it goes to the full GPS screen (no music across the top) and it takes a few seconds to load up this skin. Plus I would like to keep it with the music info across the top.
    2. I would like to disable the fade in when switching to GPS. It takes too long on my system (transitions is already -1)
    I would also like to contribute to any who is using the web browser this tip.
    I missed the OSK from 3.0. Now we only have the URL button.
    Change this line in wbrowser.skin
    Code:
    B04,101,526,98,67,"WEBURL"
    To
    Code:
    B04,101,526,98,67,"APPOSK",@WEBURL@
    This will give you the OSK on press and URL on press&hold
    You can also change the label to match
    Change this:
    Code:
    L,107,543,85,33,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFont#,"=URL","CENTER"
    to
    Code:
    L,107,543,85,33,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFont#,"=OSK","CENTER"
    or whatever u want
  6. #2196
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by lewcamino View Post
    1) I have fixed this for the next release, so it remembers what view you have it set to.
    2) I did this as personally I HATED the whole white flash and iguidance appearing, then embedding. THis makes it smoother, but yes, is slower on a lot of systems. Open the iGuidance_Music.skin, and remove the forceeffects line. That will remove the fade.
    I am not sure how much I will be on the forums for the next couple days with Fay headed out way. As far as the forecast goes, it is not going to hit here directly... BUT we are still going to get 50 MPH + winds from it. That , more than likely, means the power will be going out intermittently.
    Here is the latest radar, and yes, it is really, really nasty outside right now! (That little star is where I am located)
    My Fiero Build Thread
  7. #2197
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    Quote Originally Posted by JohnWPB View Post
    good luck with the storm!!
    if you get a moment can you look at my posts (few back)
    here i copy it:
    Quote Originally Posted by dhantiflag View Post
    so maybe this has been answered, but i couldnt find it...
    im currently using mitchjs build of the 11/7 rr
    using DFX4
    whenever i select a folder to play, then append another folder to the current playlist, then go to sirius, hd, hibernate or anything like that and then go back to audio, i lose the playlist... just the orignal folder is there nothing else.
    also how is it possible to use the unused buttons simular to LSX void does? to embed programs in?
    and some reason it wont open garmin GPS, but if i have garmin already open dsx reconizes it and moves it and resizes it propperly
  8. #2198
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    With the DFX Button editor, in the helper files folder, you can put anything you want on the empty buttons.
    Open the exectbl.ini in the skin folder, search for "Garmin" and change to the correct path on your system.
  9. #2199
    Jan 2006
    Having an issue with the browser keyboard
    For some strange reason when I type a URL and click the enter key nothing happens. The keyboard is responding (shows URL I'm typing) but it appears the enter key is not doing anything. To make matters worse there is no way for me to back out of this screen. Am I the only one having this issue?
    This doesn't happen if I use an external keyboard
  10. #2200
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    @hpric: Hmmm This is the first time this has been reported... The Enter key has the standard Key13 (Carriage return character). If you get stuck in the screen, try pressing the cancel key on the top left of the OSK.
    If you can't figure it out, I can have a look at it Sunday after next if you are going to be at the meet.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
