John, I guess this should be a bug report, but I only have a few minutes. The FM radio doesn't have a radio_menu_function.skin. Without this skin, you cannot do a local station scan on Radiator-based, ADS, or Silabs FM radios. As a work-around, I just changed the "LOCAL SCAN" button to "FUNCTION||SCAN" and copied the radio_player.skin to radio_menu_function.skin. The screen flashes as it loads the three screens and then proceeds with the scan, but its almost unnoticeable.
The "LOCAL" button could have been used, but then I wouldn't have a way to switch between the two. I guess it may may be better to use a byindicator command on the existing "scan" button: "BYIND;LOCAL;SCAN<<FUNCTION||SCAN". This would completely eliminate the need for the second button.
I read about this free program that works with Windows Mobile phones in this post http://www.mp3car.com/vbulletin/soft...e-control.html The download link for the software (myMobiler) is there too.
Since I have a Motorola Q (and none of the RR phone programs seem to work with it), I decided to give this a shot.
One of the members built a skin for "Simplisitique", so I decided I needed a lesson in skinning to make it work with my favorite skin, DFX4.0.Not bad for a first time me thinks.
Basically, I used the DFX 4.0 Phoco skin and remapped all the buttons and labels from one to the other, and guess what, it worked, even the OSK!
Now, I would LOVE to have someone check it, add stuff to it, clean it up if need be, etc. One problem I can't seem to get around is the size of the Motorola phone screen that shows up. You can see in the pics below that the right 1/3rd of it is cut off.
The coolest thing about this setup is I can use the TS to dial a number, and when the call kicks in, it fires up my Onstar / BT conversion kit mentioned here. So, I can see what is displayed on the screen, make contact list calls, and use all the functions of my phone on screen, and talk over the factory mic and speakers! The GMOS-06 kit also mutes the sound going through the amp (fades) while a call is in progress, and then fades back on when the call is over.
Here is the code for the skin. I also needed to add the path to the ExecTbl.ini file manually, it woudn't "stick" when I used the button editor for some reason.
MEDIACAR Skin
MEDIACAR Phone Skin
INC,DFX_Font_Color.txt
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B24,442,338,98,83,"ACTIVATE;!My Mobiler||SENDKEY;{DOWN}",
B23,445,149,94,80,"ACTIVATE;!My Mobiler||SENDKEY;{UP}",
B21,675,10,58,40,"PREV",""
B02,2,93,98,084,"ACTIVATE;!My Mobiler||SENDKEY;{F7}","Volume-"
B01,4,5,98,084,"ACTIVATE;!My Mobiler||SENDKEY;{F6}","Volume+"
B22,600,10,58,40,"NEXT",""
B26,2,518,103,78,"CLOSE","Exit"
B10,548,397,248,69,"ACTIVATE;!My Mobiler||SENDKEY;{ENTER}",
B08,337,529,218,67,"ACTIVATE;!My Mobiler||SENDKEY;{F4}",
B07,106,530,206,65,"ACTIVATE;!My Mobiler||SENDKEY;{F3}",
B59,443,250,91,81,"APPOSK",""
B,435,433,106,90,"ACTIVATE;!My Mobiler||SENDKEY;{PGDN}",""
B,443,56,91,81,"ACTIVATE;!My Mobiler||SENDKEY;{PGUP}",""
B03,2,178,98,082,"ACTIVATE;!My Mobiler||SENDKEY;{RIGHT}",""
B04,2,265,97,083,"ACTIVATE;!My Mobiler||SENDKEY;{LEFT}",""
B11,550,109,079,060,“ACTIVATE;!My Mobiler||SENDKEY;{1}",""
B12,632,112,080,060,“ACTIVATE;!My Mobiler||SENDKEY;2",""
B13,712,113,077,060,“ACTIVATE;!My Mobiler||SENDKEY;{3}",""
B06,2,438,98,083,"ACTIVATE;!My Mobiler||SENDKEY;{F2}",
B05,1,353,98,083,"ACTIVATE;!My Mobiler||SENDKEY;{F1}",
B20,552,321,079,70,"ACTIVATE;!My Mobiler||SENDKEY;{F8}",
B25,557,533,238,61,"ACTIVATE;!My Mobiler||SENDKEY;{F11}",""
B14,552,181,079,65,"ACTIVATE;!My Mobiler||SENDKEY;4",""
B15,634,181,079,65,"ACTIVATE;!My Mobiler||SENDKEY;{5}",""
B16,713,183,077,64,"ACTIVATE;!My Mobiler||SENDKEY;{6}",""
B17,551,254,079,63,"ACTIVATE;!My Mobiler||SENDKEY;{7}",""
B18,632,251,079,66,"ACTIVATE;!My Mobiler||SENDKEY;{8}",""
B19,712,250,077,68,"ACTIVATE;!My Mobiler||SENDKEY;{9}",""
B09,551,468,247,58,"ACTIVATE;!My Mobiler||SENDKEY;{F12}",""
B21,631,322,079,67,"ACTIVATE;!My Mobiler||SENDKEY;(0)",""
B22,713,320,077,69,"ACTIVATE;!My Mobiler||SENDKEY;{F9}",""
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L55,500,10,100,35,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"REMAININGTRACKTIME",""
L03,150,10,268,35,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
L,8,544,83,36,#DFX1R#,#DFX1G#,#DFX1B#,19,#DFXFont# ,"=MENU","CENTER"
L,570,482,197,34,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Home","Center"
L,569,548,197,33,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Screen Off","Center"
L,716,335,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=#","Center"
L,636,336,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=0","Center"
L,557,342,71,44,#DFX1R#,#DFX1G#,#DFX1B#,40,#DFXFon t#,"=*","Center"
L,716,261,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=9","Center"
L,636,262,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=8","Center"
L,555,263,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=7","Center"
L,716,193,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=6","Center"
L,636,194,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=5","Center"
L,556,193,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=4","Center"
L,716,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=3","Center"
L,636,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=2","Center"
L,555,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=1","Center"
L,570,413,197,40,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Enter","Center"
L,445,270,88,32,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFon t#,"=OSK","Center"
L,10,39,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont# ,"=Vol UP","Center"
L,10,110,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Vol DN","Center"
L,10,195,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Right >","Center"
L,10,282,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Left <","Center"
L,10,368,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Soft","Center"
L,10,392,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=1","Center"
L,10,451,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Soft","Center"
L,10,477,88,20,#DFX1R#,#DFX1G#,#DFX1B#,13,#DFXFont #,"=2","Center"
L,467,63,45,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFont #,"=^","CENTER"
L,464,179,48,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFon t#,"=^","CENTER"
L,467,87,46,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFont #,"=^","CENTER"
L,462,366,50,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t#,"=V","CENTER"
L,466,451,48,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t#,"=V","CENTER"
L,466,471,47,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t#,"=V","CENTER"
/, A, x, y, w, h, color;RGB
A01,100,81,251,395,000
L,575,65,200,40,225,51,0,22,#DFXFONT#,"=Mute","CEN TER"
/, I, x, y, w, h, Code;INDICATORCODES
I06,600,70,200,40,"MASTERMUTE"
/, Y, Back Slider file path
Y01,"\volume_slider\volume_*.jpg"
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S01,600,6,215,45,303,530,215,45,H,01,"",013,"MASTE R","Master"
END
Working on - 2006 Cadillac Escalade with all the TOYS!
COMPLETE! - 2002 Cadillac DTS - Summer 2008 - SOLD SUMMER 2010
COMPLETE! - 1998 Cadillac Deville Concours - Summer 2007 - SOLD SUMMER 2008
Nice... It's too bad the Phone integrations have seemed to fall off. None of these programs out there work with my voyager and I am not willing to give up my 3G. I hope someone comes out with something for CDMA.
Quantum: Find this line in your skin:
And replace with this one:
A01,112,64,317,446,000
That should fix the area the app appears in and let you see the whole display.
My Fiero Build Thread
Hey John,
Glad to see you weathered the storm OK!
That did the trick! TY
I'v been looking all over. And i still can't get the Spectrum Analyzer to show up at the top part of the screen?
how can i get this to work?
First I have to say that this skin is awesome! I've been a LSX skin user and just switched over to this one. Both skins are great but it feels like this one has a lot more features and more flexible.
I just got through reading all of the DFX 4.0 posts. Took a couple of days.
docbreezy requested this option below and I wanted to know if there was some way to get it working. I just setup the 5.1 surround sound on my M10K (after 3 years) and sometimes I have to minimize RR to be able to adjust my sound settings to the rear speakers and sub. I was hoping there was some way to get this integrated into the, line in, mic and aux setting in the mixer screen??
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
I did check hte Help file. And i followed the instructions. and I got the Spectrum Analyzer to work via AVS. But only on the Album cover.
I would also like to get it working on on the TOP part of the screen. So it works on the MAIN page as well.
And btw (DFX Team)...just to report to whomever is in charge of keeping the "HELP"file up to date.
The section that says "click HERE" to the the analyzer working on the first page, doest work. Infact the Hyperlink is completely gone. And there isn't a section referring to this setup in the DFX4.0 help file.
