Thread: DigitalFX 4.0
  1. #2241
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by JoyRidun
    Quote Originally Posted by boriman
    DFX 4 does not display Russian characters in the music player screen correctly. It is garbled. When I go back to DFX 3 - it works OK. Any one else noticed problems with int characters/able to fix it ?
    I have the same problem 90% of my music is in Russian and all i see is ???????
    PLEASE anyone, a solution to the problem?
    This probably would be due to the fact that DFX 4 is using my RRMedia plugin for all of the audio media handling. And sounds like a small issue in the plugin...
    Quote Originally Posted by cameronlazzari
    John-
    I am having one issue with DigitalFX4. In DigitalFX3 when you went to search for music and selected the album you could just double click the song and it would play. In digitalFX4 you have to hit play selected in order for the song to play.
    This is the way my plugin plays the songs, dbl clk'n adds it to the PL, this is one of those things that everyone will have their own preference to what action single or dbl clk'n on a song will do.
    Also when the song is done playing it doesn't continue to the next track...it just stops. Is there away to get it to be more like DigitalFX3 where it will continue to the next track like a cd?
    In order to play all songs on an album, you need to go back one step and play selected album. The thinking behind this is, if you go into an album then your most likely only looking to play a few songs otherwise you would have seen the album name and thought "i want to play the whole album" and selecting it to play not browsed.
    Quote Originally Posted by jnot2 View Post
    Thanks for the quick response.. One more question before I quit for the night. How do you add a new menu page.
    Two menu pages not enough? Hitting the menu button on the menu scn toggles between two different main menu's, giving you a total of 16 cust btns to set to your liking.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2242
    Oct 2007
    Quote Originally Posted by cameronlazzari View Post
    I am still having an issue with sirius. I shut my carpc down with hibernation in the skin digitalfx. When I start it up there is no sound with sirius. I have to exit out of roadrunner and open it again to get sound. I tried it in other skins and the same issue. Is there something I am doing wrong?
    I had it working great before I did a full format...not sure what is going on here.
    I am using a laptop.
    I contacted mitch and still am having issues...anybody help!
    have you tried Mitch's new code?
  3. #2243
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    Tis thinks it goes more like this... Vista = awful anywhere!
    no problems here, Road Runner on vista works fine for me.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  4. #2244
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by john1701 View Post
    You're the only one that I know of that has it working correctly.
  5. #2245
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by marteline View Post
    I didnīt find anyone question about the color menu... when I use this menu, I must change the background color first, otherwise, the other colors buttons donīt work... are you guys facing the same problem?
    At least a "shut up and keep trying" was spectated from someone.... hehehe...
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  6. #2246
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    do you use anything like sirius? HD radio?
    i had mine working... but not with sirius and hd radio because i couldnt select the line in...
  7. #2247
    Jan 2007
    San Francisco
    Quote Originally Posted by JoyRidun View Post
    If you didn't have this problem in DFX 3 and see it now, go to DFX settings and try changing the font. It worked for me.
  8. #2248
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Good catch... I would/did completely forget about checking if the currently used font supports Unicode...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #2249
    Jul 2006
    Quote Originally Posted by CARLOS_CET View Post
    CannonBaller
    What Main screen layout are you using? Try using the Logo with compass. Once you have that setup, click on the time and that should bring up the vis.
    Yes that worked!!!
    So the compass Logo is the only one then?
  10. #2250
    Oct 2007
    quick question, my youtube button doesnt bring anything up when pressed. Theres a youtube.skin in the dfx4 folder but it wont open when pressing the button. Someone was having this same issue and John said there was a line at exectbl that executes the skin. My rr.ini doesnt have any reference to youtube.skin . I've been draging the same rr.ini since version 2.0. Will renaming rr.ini to something else and letting the rrconfig app rebuild a new one fix this issue?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
