Thread: DigitalFX 4.0
  1. #2271
    Jul 2006
    Gps Gps Gps
    This may have a simlple answer, but can't seem to find the solution.
    Im using Garmin Mobile PC. The issue is that it won't start up from with the DFX skin.
    - i changed the DFX skin button to "Garmin GPS"
    - i setup the RRconfig to use Garmin QUe, with the correct CommPort
    When i click on the GPS button. All i get is a blank screen with the buttons on the bottom (Garmin Skin, i assumig).
    The only way i can get the button to actually bring up Garmin is by first going to "MUSIC", then clicknig on the GPS button there. Once Garmin loads, i can now click on the "GPS" button again (outside of MUSIC, aka The Garmin dedicated button).
    From this point on i can go in and out of the menus including the Garmin "GPS" button without issue.
    So i guess what im asking is.
    How can you get Garmin Mobile PC to start just by clicking on the dedicated GPS button.
    I checked the ini settings in the EXTERNAL section of the DFX skin, and i found an entry there that was point Garmin Que to the "I" drive. I swiched this to "C", but didn't make any difference.
    ANyone able to get this working properly?
    thanks
  2. #2272
    Jun 2002
    Virginia
    Nice job, John. Not knowing CPR or keeping a first aid kit in my car (which I probably should), there's no way I could have done what you did. I do hope most people would stop long enough to make a 911 call in that situation. Was it a bad part of town?
  3. #2273
    Dec 2005
    Dear All.
    The skin is very good , but i have a problem with the freefone.
    every time i start the phone the FREEFONE is running outside of the skin and i cannot close it.
    So , i need to close the RR from taskmanager and kill the proccess for the freefone.
    how can i fix it?
  4. #2274
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    John, that's really impressive. If you were not to have performed CPR on that guy, he would have been dead. Hopefully that guy is fine. Much respect to you for what you did.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  5. #2275
    Sep 2007
    Sussex, England
    Well done John, seems there really are no problems you can't solve!
    I know Roadrunner has many features, but saving lives ?!? lol
    Also wanted to remention the problem I'm having with RR/DFX 4.0 chatting s**t, it quite often, usually when booting PC up, or browsing music, is talking to me, and doesn't seem to wanna ever shut up! Says things like 'background reset', 'setting coms', 'user switch' and some other random jargen.
    I think this might have something to do with the user function on DFX 4, as I didn't get this problem with 3.0.
    I didn't want to report as a bug, becuase it probably isn't, just would like to know if anyone else has/had this problem and if there is anything I could do about it.
    Thanks for your time,
    Phil
  6. #2276
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Turn off voice
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #2277
    Nov 2006
    Arizona
    Will this skin work with mitch's version of RR?
    Link to MitchJS' RR
    Thanks,
    -CoryF
    2001 Camaro SS #2070
  8. #2278
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    mostly
    having read through most of the posts on DFX4 and mitch's RR, you could run into a couple of things, but for the most part it works.
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
  9. #2279
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Talking New weather selector.....
    Ok, there was one last thing bothering me about the weather pages. That was putting in a location correclty. In Florida for instance, if I would put in "Miami" It would set the location to Miami, AZ (Who even knew there was a Miami in Arizona!?!)
    After some tinkering, and a small but of scripting, I think I solved it! Now if there is more than one location with that city name, a menu will come up allowing you to choose the city that you want. This is also helpful for area's other than the United States, as it will usually show a list of cities, and allow you to choose one.
    Here is a little preview of it in action:
    My Fiero Build Thread
  10. #2280
    Oct 2007
    Awesome John!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
