Page 23 of 557 FirstFirst ... 13141516171819202122232425262728293031323373123523 ... LastLast
Results 221 to 230 of 5570
Thread: DigitalFX 4.0
  1. #221
    May 2005
    Mother Earth
    Quote Originally Posted by Smitty0881 View Post
    Just loaded the skin and everything works perfect. No problems at all. Great job John. U da man
    -Smitty
    Curious smitty when you say everything works perfect what did you test.
    Which 3dlogos did you use.. Try the b&w_wall clock did it close when clicked.
    did you get signal readings in the wireless skin?
    did your gps program pause when giving directions?
    did your menu in the IE browser have a shawdoeed to the word menu?
    did your jukebox not let you delete a file you downloaded
    did most of the songs you try and download say not there.
    did the screen cleaner exit correctly for you..
    did you have any issues with xm not showing signals.
    if all that works please send me your ini file and ya hardware descriptions..
    KIAs can have car pcs too..
  2. #222
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    Quote Originally Posted by nigwhyrito View Post
    my guess is he didn't try everything, just what he uses...if not, I would also be curious how you got the wireless stats to show and how you got cdrip to work.
    EDIT**
    Quote Originally Posted by brandensin View Post
    Hmm.. task manager.. I can kill a process when viewing in task manager....
    but, in open windows, whenn click end task button, it just removes the name and the process still running...
    Can anyone confirm this?
    Confirmed
  3. #223
    Low Bitrate jjnit's Avatar
    Feb 2007
    EDIT:: SOLVED
    Thanks to treetop777, nigwhyrito, and BREWDOG52 - these are fixed (my issues).
    Edited the skins file for the temp sensors, and installed flash via IE instead of firefox to fix the flash.
    Ok - ran into one problem and have one request, I've searched and don't see this so far (but I'm sure someone will show me wrong as soon as I post.)
    The problem is on the wallpaper selection screen - I see a white box where I assume some sort of live preview should be as so:
    And the request - is there any way to lose the temperature sensor headings on the main screen (circled below)? If not, no biggie...
    Thanks!!!
  4. #224
    Aug 2007
    Oregon
    Quote Originally Posted by jjnit View Post
    Thanks!!!
    Use the skin editor
    or delete these lines from menu.skin & menu2.skin
    L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP2","left"
    L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
    L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
    L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP1","left"
    EDIT**
    Quote Originally Posted by dmistry View Post
    Thanks John, if anyone takes me up on my offer I will make the icon package available to you so you can add it to your downloads.
    Come on all you photoshop experts start creating some cool new icons..
    waiting for you to send me a pm, I got the day off, so I can work on it today if you get back to me
  5. #225
    May 2005
    Mother Earth
    Thanks!!!
    hmmn that white area i am thinking you dont have the background location right in the .ini or no flash or shockwave installed. Is that the animated nissan logo.
  6. #226
    Feb 2007
    Quote Originally Posted by BREWDOG52 View Post
    Use the skin editor
    You rock - thanks!
  7. #227
    Aug 2007
    Oregon
    You rock - thanks!
    yeah I do no problem
  8. #228
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    That background preview is a flash file so he/she may indeed need to install or update flash player..
  9. #229
    Jun 2002
    Virginia
    Quote Originally Posted by barnyard View Post
    Ok, I think I've got the signal meters sorted out, but I can't verify because I'm at work. Anyone want to try it out and let me know?
    XM signals work fine for me. Thanks.
  10. #230
    Feb 2007
    Quote Originally Posted by treetop777 View Post
    Dang it, I forgot you have to install flash via IE and not firefox to do it correctly. Thanks for the reminder - I've been out of the loop for a while.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
