No i jsut downloaded it installed and did nothing...
where can i find the un-corrupted version?
THANKS SO MUCH for your help! At least i know whats wrong now
Have you by chance gone in a manually changed something in it????
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Here is my exectbl.ini by the way
OK i think i understand what happened.
its a problem with Japanese Windows.
See when US PC uses the \ for directory, japanese PC uses a different symbol, thus everythign stops working.
Thanks for the help BlueZX3!
.......... my problem with the button editor.... anyone ????
Have you (manually) changed anything in the skins exectbl.ini file? Next, are you using the supplied newer button editor as opposed to the one from dfx 3.0? you should have swap and delete buttons in the top right corner area if its the correct one to be using for 4.0.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
i've not changed anything in the ini file, And i'm using the button mod supplied with the 4.0 installer......
Should I assume that error message appears when trying open the editor?
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
