Thread: DigitalFX 4.0
  1. #2431
    May 2008
    I've seen a number of skins which have .ini files for the various components which have "C:\Program Files\Road Runner" hard coded in any number of places causing a bunch of things to fail if you installed in "RoadRunner".
  2. #2432
    Sep 2008
    at risk of being "capslocked" can I ask if DFX and the garmin OSK work together nicely ?
    I'm sat on a train on my PDA ATM, so can't do a proper search ( joys of crap UK roaming )
  3. #2433
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Any hard code paths anywhere in a plugin or any app for that matter shows bad programing style...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #2434
  5. #2435
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Dirtyrhino View Post
    YEAH, IT WORK FINE. JUST GOT TO SETUP A BUTTON IN DFX WITH THE COMMAND TO CALL IT.
  6. #2436
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Should have seen that coming...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #2437
    Aug 2006
    How do i disable iList in the new DFX 4.0? it's not where it says it is in the original post
    reason i need to disable it is because i can't see any lists of anything when i go to music -> browser or to digital fx settings to change the logos and stuff. it's just blank and if i click "Browser" after going to "Music" the whole program locks up.
    i have the most up-to-date flash player, the most up-to-date DFX and most up-to-date directx.
    thanks
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
  8. #2438
    Sep 2008
    Quote Originally Posted by treetop777 View Post
    yeah, it work fine. Just got to setup a button in dfx with the command to call it.
    lol !
  9. #2439
    Sep 2007
    Sussex, England
    iNcArCeRaTiOn, have you tried updating your graphics driver ?
    I had similar problem after reloading XP on my PC, and after much deliberation, found it to be the driver that I hadn't reloaded at that point.
    Otherwise, I think (not in front of DFX at the mo) that you'll find it somewhere in settings, DFX skin settings, and is an option to turn ilists on or off.
    Hope this helps
  10. #2440
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    To turn off iLists globally, put this in the RR.ini:
    usedx=false
    This is something that was added in the latest build of RR that was not documented.
    My Fiero Build Thread
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
