Thread: DigitalFX 4.0
  1. #2511
    Newbie rocsell's Avatar
    Mar 2008
    I'm trying to find the location of the built-in calculator used for entering figures in the Utilities, Mileage and Trip option...the values in my calculator show up blank..
  2. #2512
    Sep 2008
    is there a way to change the location for the weather forecast?
  3. #2513
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by bongta029 View Post
    For the 1 and 5 day forecast, you just left click and hold one of the five buttons at the top of the screen until the keyboard pops up. Enter your city and state, and click on enter.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #2514
    Newbie GhostRiderDad's Avatar
    Apr 2008
    Hi all!
    I have tried to search for a response to my questions, but have not found any.
    1) With the addition of the new song search database, is there a way to take the results of the search and create a playlist from it? I don't like to search for songs when I am driving, I'd rather do a search while at a light, and then play the entire list without having to pick and choose from the list.
    2) I've had an annoying problem with winamp sometimes having the volume at zero when I startup Roadrunner and DFX4. Has anyone else experienced this?
    3) I know its been said in various spots thoughout this thread, but I think it would be a good thing to post the optimum versions of Winamp, and RoadRunner for each release of DFX in the appropriate FAQ. Forgive me if it is already listed somewhere, but I have not found it.
  5. #2515
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by GhostRiderDad View Post
    When you do a search it creates a playlist called "results". Load the playlist and you're good to go.
    Add "setvol;master;10" to the onstart line of your exectbl. The number is the volume percentage that you want RR to start at.
    The optimal version of Winamp and RR differ depending on the user. I'm sure John has an opinion on it though.
  6. #2516
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    Quote Originally Posted by rocsell View Post
    I am having the same issue so I wonder if it is a global issue or not (being blank)?
  7. #2517
    Aug 2006
    Quote Originally Posted by Machinehead View Post
    Add "setvol=10" to the onstart line of your exectbl. The number is the volume percentage that you want RR to start at.
    I don't have volume at zero issues on start (thankfully) but this does nothing for me.
    I have done some reading in regards to "setvol" through the skin commands and around here to set my volume at a predefined value regardless of what it was on shutdown and it doesn't seem to do anything when added to the exectbl.
    Skincommands (RR) shows something like this "SETVOL;Wave;50" (substituting "Wave" for "Master" in my case) but it doesn't seem to work either (this might be me missing something though)
    From my searching it seems that 5.13 seems to be the version to have for now.
  8. #2518
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, after yo do your search as machinehead said click the "Manage Playlist" button and it will be the top one in the list aka "[Search Results]" then just load it.
    The only two winamp versions that work best with rr are 2.95 and 5.13, JohnWPB and LS have tried many different versions and both have come to the conclusion that the 5.13 is best as also stated in the the dfx help file...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #2519
    Apr 2008
    Thanks Blue, I knew you'd come through! (Intentional Rhyme!)
    So I did a bad thing by upgrading to Winamp 5.54? It seems to work fine....so far.
    How would I (or should I) download an older version of winamp?
    Kudos gentleman, for all your hard work and great interfaces.
  10. #2520
    Jun 2007
    Quote Originally Posted by bungee91 View Post
    I screwed up the command, thanks for catching that.
    I don't have my exectbl file in front of me, but if you place the setvol command in the onstart line, it'll set the volume to that level everytime you start RR.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
