Thread: DigitalFX 4.0
  1. #2521
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by GhostRiderDad View Post
    Thanks Blue, I knew you'd come through! (Intentional Rhyme!)
    So I did a bad thing by upgrading to Winamp 5.54? It seems to work fine....so far.
    How would I (or should I) download an older version of winamp?
    Kudos gentleman, for all your hard work and great interfaces.
    Mitch and I have discovered that using a newer winamp version creates issues with the the winamp.dll file that rr uses to talk to winamp. It has to deal with retrieving the tag data from the newer versions as something changed and the dll file can't compensate for it.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2522
    Newbie GhostRiderDad's Avatar
    Apr 2008
    Sounds like an opportunity for a RR enhancement! I"d volunteer, but I have no idea where to start. What is the module/class/code in the source code that is tied in to the DLL that controls winamp? 5.13 was some time ago. I have noticed with the version I am using, the tag info is screwy. Everything else works fine.
  3. #2523
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The other reason for using the 5.13 ver is also b/c that seems to be the only one that will allow rr to properly embed the visual's in the correct location as well..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #2524
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    Quote Originally Posted by Machinehead View Post
    I screwed up the command, thanks for catching that.
    I don't have my exectbl file in front of me, but if you place the setvol command in the onstart line, it'll set the volume to that level everytime you start RR.
    Yeah correcting wasn't my intentions, I more had a question of the right way to implement this to have it work correctly, as doing it the way I explained, or you doesn't result in it doing anything for me.
    I assume this works for others and I am just doing something wrong?
  5. #2525
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    rr.ini or in the config:
    startcommand=SetVol;Master;25
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #2526
    Apr 2008
    I take it that the newer version of winamp, the playlist would not work right either? I do not see the playlist as built by the database engine, but at least it works, but does not create a playlist for me to play. Looks like I'll be doing some fixing this weekend to make sure all the versions are correct for optimum performance with RR and DFX 4.
  7. #2527
    Aug 2006
    Now THAT's what I'm talking about works perfectly!
    Nothing I read had the "startcommand=" part which I either overlooked or just didn't know well enough to insert in there.
    Thanks!
  8. #2528
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Other than the dll issues Blue mentioned, Winamp 2.95 does not work with the transparent visualizations. 5.13 works perfectly, as where 5.15, 5.17 ect ect MAY work, but most of the other versions, other than 5.13, when ran, do not lock the visualization in place in RR. It will appear 100 pixels or so over and down from where it is supposed to be.
    My Fiero Build Thread
  9. #2529
    Aug 2006
    Quote Originally Posted by JohnWPB View Post
    Ok, I have been re-working the DFX custom font here, and I think I have come up with a fix for the fonts displaying wrong at 800 x 480 resolution.
    If someone could test this out on their system, and let me know how it works for you at 800 x 480, that would be great.
    Not sure if you got any feedback on this but wanted to give you my thoughts as I run 800X480 in the car.
    It works great on the screens I have used except for the video screen.
    The buttons seem to "droop" towards the right.
  10. #2530
    Apr 2008
    John,
    Where do you reccomend I can download 5.13? I saw a site called winamp heaven. it has quite a few versions there. The difference between the latest version and 5.13 is that the latest version is twice as big!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
