Thread: DigitalFX 4.0
  1. #2541
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by anarchyonline View Post
    Already did that.
    The dll file is supposed to be placed in the RR root folder and not in skins>DFX4 right?
    Belive you have to be running the 9/10/08 (or above) rr.exe and/or it might be the order in which x,mp3art is listed in menu.skin.
    Also test it in other skins to make sure it's a DFX problem.
  2. #2542
    Newbie anarchyonline's Avatar
    Feb 2007
    Buffalo, NY
    Quote Originally Posted by treetop777 View Post
    I will try that when I get home today. I believe that I installed the 9/10/08 release of RR but I have to make sure that the installation was successful. NOD32 deleted the file during installation thinking it was a virus, so had to disable the realtime scan and add RR to exclusion list. Did a reinstall and it seemed ok. How do I check on the version anyway?
    CarPC Specs - AOpen MiniPC w/ Celeron Proc, 1GB RAM, 160GB HD, Holux Mouse GPS Receiver GR-213, Dynamix 816 8" Touch Screen LCD, Carnetix CNX-P2140 DC-DC Regulator. Digital FX 4, Wireless A/B/G, Garmin Mobile PC, iGuidance 4
  3. #2543
    Sep 2008
    Quote Originally Posted by mdawg View Post
    When I try to build my Music database all I get is a Port Error?? Any help?
    I get the exact same error...any thoughts or fixes?
  4. #2544
    Sep 2008
    Hey John, again another great skin. I updated from DFX3 to DFX4 and loving it. I also decided to switch from IG4 to Garmin Mobile PC (see how it performs vs. IG4).
    A few issues that I had:
    1. When I chose the Garmin GPS from the buttons selector, it would open the Garmin GPS skin but not launch the program. I think I fixed it by changing the menu.skin file to include external_gps.skin or something to that effect. This in turn launched Garmin. (I have to retrace my steps and repost)
    2. Garmin was getting chopped off at the top where the directions were being displayed. I changed the Garmin_GPS.skin to reposition the window so that it would not get chopped off at the top. (I will repost the window coordinates when I get home from work if anyone is interested)
    I have to see if I like it on widescreen mode. I was getting really used to the 1024x768 resolution. Right now, I am a happy camper! Yet again, great work John.
    hya - I was having issues - but mine are all fixed now - dead happy
    On a separate note - in DFX4, while in the player itself, if I tap the GPS button - what should happen ? Should it flick back to the original GPS program ( GMPC ) if it's already open ?
    Cos mine isn't...
  5. #2545
    Feb 2007
    Buffalo, NY
    Quote Originally Posted by Dirtyrhino View Post
    Cos mine isn't...
    The GMPC should open in the window where the Album art goes. It is working for me but it overlaps the buttons on the right (Browser, Manage Playlist,....)
  6. #2546
    Sep 2008
    Hmmmmm. I though it should.
    Running my screen @ 800x600 ATM. Works fine when I call it on it's own.......maybe i'll just not prod that button then. but it'd be nice to have it working properly
  7. #2547
    Feb 2007
    Buffalo, NY
    Mine had that issue at some point in time I believe. I have to check when I get out of work. On another note though, it might not work as well if you are running your resolution at 800x600, GMPC would probably take up the majority of your screen when you are in the audio player. I had to resize my screen to 1280x768 for it to look right-ish.
  8. #2548
    Sep 2008
    OK, i'll have a fiddle later on once xp has finished ( another ) security update and see if it makes any difference
  9. #2549
    Feb 2007
    Buffalo, NY
    Right or wrong, try this... in your skin.ini dfx4 folder, change GpsScreen=Garmin_GPS.skin
    Then, in the main menu of dfx4, select and hold down the button for GPS, select iGuidance when the menu pop's up.
    In RRConfig, set GPS Mode to external, GPS Path to <your Garmin Path here>\Que.exe and Window Name to Garmin Mobile PC.
    Let me know if that works.
  10. #2550
    Feb 2007
    Buffalo, NY
    I reinstalled RR and now it works! Apparently the first install didnt take when NOD32 interrupted me. Awsome!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
