Thread: DigitalFX 4.0
  1. #2551
    Jun 2008
    Anarchy Im having the same problem with Garmin when using the overlay. The top bar and bottom bar show up but the actual program never launches. What did you do again to fix it?
  2. #2552
    Newbie anarchyonline's Avatar
    Feb 2007
    Buffalo, NY
    Quote Originally Posted by mdawg View Post
    Try this:
    Quote Originally Posted by anarchyonline View Post
    Right or wrong, try this... in your skin.ini dfx4 folder, change GpsScreen=Garmin_GPS.skin
    Then, in the main menu of dfx4, select and hold down the button for GPS, select iGuidance when the menu pop's up.
    In RRConfig, set GPS Mode to external, GPS Path to <your Garmin Path here>\Que.exe and Window Name to Garmin Mobile PC.
    Let me know if that works.
    CarPC Specs - AOpen MiniPC w/ Celeron Proc, 1GB RAM, 160GB HD, Holux Mouse GPS Receiver GR-213, Dynamix 816 8" Touch Screen LCD, Carnetix CNX-P2140 DC-DC Regulator. Digital FX 4, Wireless A/B/G, Garmin Mobile PC, iGuidance 4
  3. #2553
    Feb 2007
    Buffalo, NY
    Does anyone here know how to tag/add 2 commands to a button? I would like to know if you can include 2 commands in one line of code. As I have it now, to load a playlist:
    (Not the exact button command but just an example)
    B20,525,92,255,29,"=Load"
    B20,525,92,255,29,"RELOADSKIN"
    This was needed to solve the issue when a new playlist was loaded (or disk is changed), the Album art does not refresh and the ID3 tags were not loaded properly.
  4. #2554
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Join them with a double pipe "||"
    B,.............,"<command>||<command>"
  5. #2555
    Feb 2007
    Buffalo, NY
    Quote Originally Posted by treetop777 View Post
    Awsome, thanks!
  6. #2556
    Jun 2008
    Try this:
    Ok I am at school right now so I will try it when I get home. I don't get the holding the gps button because I am not using that option because I only have Garmin I do not have iguidance.
  7. #2557
    Feb 2007
    Buffalo, NY
    It will still launch Garmin (even though you select iGuidance as the button) if you set the external GPS path as Garmin (Que.exe) in the config tool.
  8. #2558
    Jun 2008
    Still does nothing other than put the overlay, even with garmin mobile already running separatly it does not display in the program.
  9. #2559
    Feb 2007
    Buffalo, NY
    Thats interesting. My initial problem was it wouldn't launch Garmin but if Garmin was already launched, it would put it in the overlay. Your issue might be different then.
    Did you check to see if you set the Window Name in RRConfig to be Garmin Mobile PC?
    Try this, with Garmin running, bring up the Windows Task Manager. Under Applications tab, look for garmin. Take the exact app name that is being displayed and enter it as your "Window Name" in RRConfig.
  10. #2560
    Jun 2008
    Dunno, I rechecked all my steps with the overlay and they seem to be correct.
    On another note as well, this is what happens when I try to build my Music Database. (sorry saved the photo in a low format)
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
