Thread: DigitalFX 4.0
  1. #2591
    May 2007
    Bothell, WA
    my logo in the middle is not displaying..is there something else i have to download? it worked(works) on dfx3..but for some reason it doesnt work on dfx4..any help?
  2. #2592
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Make sure you have the latest RoadRunner.exe, as some of Mitch's older versions would not show the flash logo's in the center.
    My Fiero Build Thread
  3. #2593
    May 2007
    Bothell, WA
    okay..ill try that..thanks!
  4. #2594
    Low Bitrate overlander's Avatar
    Feb 2008
    Is there a piece of code I can add that would let me display altitude and/or lat/lon on the main menu screen where the clock is at?
  5. #2595
    Nov 2004
    St Louis
    John, I truly love your skin, but I just found an issue last night when I upgraded my RRMedia that requires your assistance. I now have four skins that utilize the RRMedia plugin. The issue I found is that all use the same 10 disk changer except DFX4. If I switch to DFX4 the previous skin's 10 disk changer is replaced by the current DFX user's 10 disk changer and when I switch to another skin from DFX4, RRMedia says all disks are empty.
    I tried backing up all disks from within the other skins so when I go back to them I can restore, and this works for switching between the other three skins, but as soon as I use DFX, that restore file is wiped clean. Maybe in your next update, you can backup and copy the current user's 10 disk changer restore file back to RRMedia on skin changes to preserve the current 10 disk changer info for other skins to use. I have no idea how you would keep another skin's 10 disk changer settings when switching to DFX from another, maybe not load the user 's changer but just load its restore file in case the user wants to load it.
    Another thing is how do I copy the cd changer data from one user to another?
  6. #2596
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Look in the scrips\BackupUser\UserX folder as that is where everything is copied/moved to/from
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #2597
    Jun 2008
    Atlanta, GA
    Non-transparent version?
    I love DFX, but my less-than beefy system is running a little slower than I would like. Would turning off transparency improve the performance any? How would one go about doing that? I would imagine that I'd have to re-do all of the on/off images for the different screens with a fixed background -- do I need the original .psd files? Lastly, what features would be lost by going this route? Sliders, etc.?
  8. #2598
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You will not be able to run this skin w/o transp until you go through all the screens that you'd use and apply a background to both the off/on images other wise you get what the effect of nothing showing up until you mouse over the button images. One other small thing you could to at least on the main menus is to appy the button icons to the actual images as that would keep rr from having to constantly update all of those indicators.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #2599
    Aug 2008
    Quote Originally Posted by Machinehead View Post
    What version of RR are you using? I haven't tested the latest build in the car yet, but the 9/23/08 version works fine.
    Using RR Config it updated the version I installed to 1.0.1.2
    This one has been covered a bunch of times and it's in the helper file. But there are hidden touch spots on the main menu. This particular one is at the top of the clock/logo area in the center of the screen.
    Sorry, your right, I've read so much I missed that one in the help file.
    Will configure as per instructions.
  10. #2600
    Jun 2008
    Atlanta, GA
    I went ahead and compared the performance to the non-transparent Carwings, and it didn't seem to be enough of a difference to warrant all that trouble. I did pre-load some of the screens, which bumped up speed a ton (gotta love when the answer you need is already in the manual )
    Also, it seems that I get two GPS indicators at the top of the menu:
    Is that intentional? Deleting one should be trivial, but I was wondering if it's something I made happen in my tinkering...
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
