Thread: DigitalFX 4.0
  1. #2691
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Don't worry about that calendar...its probably not gonna be there in the next update.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2692
    May 2008
    I downloaded the latest flash, still around 100% usage at times. Always about 70%, and its pretty unresponsive and slow.
    I'm probably gonna blow away RR and start over to see if that helps.
    It is easy to Embed Garmin in DFX with the overlay? I saw some people having issues.
    --Well, that did not do it. Still around 100% after a reinstall of RR and the DFX skin.
    Also, I have to keep unplugging the Garmin USB adapter every time I exit it.
    For the Garmin Overlay, what button accesses my GPS Screen? I just installed DFX, and I am looking at the Overlay Readme. I am lost at this point:
    on the button that accesses your GPS screen, you will need to change it to this:
    What file has the button that accesses my GPS Screen?
  3. #2693
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    is anyone here using mitch's volume fade plugin in DFX 4.0?
    i can't get it to work... tried placing the files and code in different places but it seems the plugin either isn't being recognized properly by DFX or it isn't running period... DFX says that the plugin is "ON" and thus "installed", but it never actually operates right, and i can't tell from the debug files that it is running at all. the plugin works perfectly and easily in other skins.
    anyone have it working? where did you place your dll's and code? it's probably a simple fix or a matter of placing things in the right spot.
    just for reference... i tried placing the "x,RRFadeVolume" code in menu.skin, plugins.txt, exectbl... all of which didn't work. Also, I had to place all the files directly in the root RoadRunner directory. Placing them in a folder within "MJSGadgets" caused DFX to say "OFF, Not Installed" for the plugin.
    here's the topic thread for the plugin: http://www.mp3car.com/vbulletin/rr-p...adevolume.html
    Any help?
  4. #2694
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    Are calendars a thing of the past, or is there some new fancy one coming?
  5. #2695
  6. #2696
    May 2008
    I got the OSK working, I just finished reading the entire thread here at work. Man what a long thread.
    Anyway, now I know I read somewhere else about exiting RR and Garmin not closing, but I will have to search for that. ** Duh, found it
    closeapps=true
    Will try when I get home.
    And I am still having the unusual CPU load, I'll try removing flash and reinstalling, then going through the steps to make RR run faster.
    It was performing horribly last night though, pretty CPU intensive.
  7. #2697
    Aug 2008
    DVD problem
    I have read many of the threads and searched over and over, but I have not been able to find my answer. I have correctly set the path to the mpc player in rrconfig. The DVD works correctly, but when I press menu and come back to the dvd it restarts? Is there an easy fix to this problem. THanks
  8. #2698
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by bungee91 View Post
    Quote Originally Posted by Enforcer View Post
    No, the world is going to end before Johns next update.
    We weill have to just wait and see which one happens first....
    Just in case, the skin is released first:
    Blue has been working on a new calendar extension plugin for RR. It is gonna kick butt! Being an extension plugin, all code is native to Road Runner, and there is nothing to embed. It will be a standard calendar view in the skin. The power comes in that it will display any holidays (some by default) and others you can add to the ini file.
    It will also be a scheduler. Click say November, 25th on the calendar, you can then enter a time and text, and reminder option. If you set reminder option to "7" for instance, 7 days out (November 18th) when you start the CarPC will tell you your event is in 7 days, and get a reminder each of the 6 remaining days that you start RR. If you set it to 1, it will just remind you the day before, and of course on the 25th.
    Here is a beta run of it in the skin. Notice on the 26th the day is highlighted in yellow. That lets you know you have entered a schedule for that day. Clicking on it will let you view, edit, delete it ect.
    My Fiero Build Thread
  9. #2699
    Oct 2007
    so whens the next release!??!
  10. #2700
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by dmistry View Post
    Now that's a calendar...where's my checkbook!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
