Um...or you just hit select and select all the filetypes that you know that you have. Or maybe I need to also add the playlists(.m3u's) as well.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
should maybe just have it say "Audio and Playlist file types"
i think that would fix the confusion
ps - any thoughts on my post a few back re: RRFadeVolume plugin in DFX?
I applied the RR update the other day, and since then the labels for audio control on the bottom of the DSX 4 screen changed to 0 - 9.
Was there a font change, or anything else I can look at the see if it changed? Or a relatively simple way to get the labels back?
I did try to search, but it appears as though there is a problem on MP3car at the moment.
I can't remember if this is the correct fix or not, but its worth a try. Under the C:/Program Files/RoadRunner/Skins/Digitalfx 4.0/Helper Files/Fonts folder, there should be a digitalfx font that I Believe [I] needs to be in your Windows font folder. Like I said, I think this is right, but I've been known to be wrong every now and then![]()
Has anyone here done anything with this Skin and the Fusion Brain Plugin from Sonix? I am waiting to control my many fog lights and such and was wondering if it would be possible to create a "Lights" Button that would take me to a separate screen with labeled buttons such as "Fog lights" Roof Lights "Rear Lights" etc... Any thoughts?
I found a problem . If I press DigitalFX4 any button(unless press "Music" button) ,it's no any response. So I use RR tool skiner to monitor the debug log,it show :
============= Debug log ========================
BYVAR;MAINBUTTON1;MyApp01<<MyApp02<<MyApp03<<MyApp 04<<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<M yApp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp1 5<<MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<My App21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26 <<MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyA pp32<<MyApp33<<MyApp34<<MyApp35<<MyApp36<<MyApp37< <MyApp38<<MyApp39<<MyApp40<<MyApp41<<MyApp42<<MyAp p43<<MyApp44<<MyApp45<<MyApp46<<MyApp47<<MyApp48<< MyApp49<<MyApp50<<MyApp51<<MyApp52<<MyApp53<<MyApp 54<<MyApp55<<MyApp56<<MyApp57<<MyApp58<<MyApp59<<M yApp60<<MyApp61<<MyApp62<<MyApp63<<MyApp64<<MyApp6 5<<MyApp66<<MyApp67<<MyApp68<<MyApp69<<MyApp70<<My App71<<MyApp72<<MyApp73<<MyApp74<<MyApp75<<MyApp76 <<MyApp77<<MyApp78<<MyApp79<<MyApp80<<MyApp81?
"SkinButton2 [hl]<<-------The music skin can open[/hl]
Audio
LOAD;Menu.skin
SkinButton2<<-----Press DVD button (No response)
SkinButton3<<-----Press Weather button (No response)
SkinButton4<<-----Press Video (No response)
temp Solution:
If I change PC setting of 【Regional and Language Options】→【Standard and Formats】 "Chinese(Taiwan)" to "English(United States)",the problem has solved.
It has any idea to real solve?? TKS..
