Thread: DigitalFX 4.0
  1. #2781
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    If you P&H on the browser btn it will ask you which browser method you want to set for that btn.
    Yes, there has been an update(s) since the skin's release which included RRMedia v1.0. All you need to do is to install the v1.2.2 patch and if you do not get a message box telling you that you db needs to also updated to the newer format then run the db updater in the RMDatabase folder.
    Alrighty then.. Thanks!
  2. #2782
    Nov 2007
    PA
    Urgh...I installed the update and it seemed to go fine. Upon trying to do a rescan of the database, it checks all files. During it's "Checking file list" it comes up with an error stating File "RMbuild.exe" not found. It freezes. I checked in the RRmedia folder in RR and the file is there...I cannot simulate this on my laptop with the same patch applied.
  3. #2783
    Nov 2007
    PA
    *SOLVED*
    Deleted Database file and rescanned. Finished error free and works great!
  4. #2784
    May 2008
    Yikes! If it's not one thing it's another! I forgot to renew the domain name JohnWPB.com. I just paid for the next couple years, and it should be back up and running in the next 24 hours or so.
    muchas gracias amigo...
  5. #2785
    Jun 2008
    hello to all guys I use dfx4 with rr, I have a problem with the configuration of sygic, integrated into the skin of garmin_gps and if I hit a pulasante to send forward a song I go away from the skin rr.
    how do I make them stay?
    because if you use the logos rotating processor I always 100%?
    I use an antenna gps bluetooth with the phone bluetooth everything with a stick possuno you use both together?
    or bigogna have 2 bluetooth keys?
    through aid and sorry for the poor English ...
  6. #2786
    Nov 2007
    PA
    uh...Little more of a language barrier than I can determine. You're saying RR crashes when you press something while in GPS mode?
  7. #2787
    Apr 2008
    HI
    I want to install destinator 7 in my RR , i have found the skin .
    But i do not know where can i buy the software?
    Someone can help me.
    thank you
  8. #2788
    Dec 2007
    Denver, CO
    Quote Originally Posted by Dougw133 View Post
    Nope.... The JPEG or album art image needs to be in the folder containing your music... Lets say you have a MUSIC folder... In that folder you have Several Artists, and then in the Artists folders you have albums. In the album folder you have your actual MP3's or songs. The image file needs to be in the folder with the songs to correlate with that album. You can also place an image in the Artist folder if you want so you can to see album art just when browsing the artist. So, they do not all go in one folder of album art. They need to be in indavidual folders with the actual songs or album folders correlating with that song... For example: If I wanted a picture of myself as album art for Dave Matthews Band album Under the Table and Dreaming, I would put the image of myself in the Under the Table and Dreaming Album folder along with the song files. When I select that album the image or "art" of myself would come up. You just need to play with it. You'll get it.
    For some reason, I am not getting album art to work at all. A couple of notes:
    1) My music collection has survived several different computers, but as a result has some oddities to it, but for the most part the music is organized by Artist\Album folder structure
    2) I have several different .jpg files in each album folder, typically with the filename "Album_Art{guid type number here}", each the same name but different sizes. I speculate that the album art got named by an old media player (thanks, microsoft).
    3) Thinking maybe it needed to have just ONE .jpg in each folder, I experimented with a couple of folders and renamed all but one jpg to .jpg.old... no luck
    I have searched and searched on this issue, but I can't seem to find the issue.
    Anyone have any ideas? Thanks in advance!
  9. #2789
    Nov 2007
    PA
    Try removing all but one jpg from a folder. Make sure you have your album art set correctly in RRconfig.exe
    There really isn't too much to it. Take a folder. Doesn't put ONE jpg of your choice into it and browse it in RR/DFX4...You should see something.
  10. #2790
    What is the VPL number mean under the music browser menu?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
