Thread: DigitalFX 4.0
  1. #2791
    Dec 2007
    Denver, CO
    Quote Originally Posted by Dougw133 View Post
    Try removing all but one jpg from a folder. Make sure you have your album art set correctly in RRconfig.exe
    There really isn't too much to it. Take a folder. Doesn't put ONE jpg of your choice into it and browse it in RR/DFX4...You should see something.
    Thanks for the quick reply... OK, eliminated all other .jpg's from the folder (even the ones I renamed). So now, entire contents of folder are the .mp3s and one .jpg
    Checked RRConfig.exe, made sure that under Page 1 of the Music tab, the Album Art box shows *.jpg
    Saved config, restarted computer, still no dice.
    What else can I try?
  2. #2792
    Dec 2007
    Denver, CO
    Quote Originally Posted by gr8scott_o View Post
    OK, figured it out. All of my album art had the "Hidden" attribute set for some darn reason! Again, a victim of some program sometime in the past that set it for my "convenience".
    Altered that, and album art now shows up as God intended...
    Just in case anyone else runs across this same issue, I used the following dos command to do it:
    attrib -S -H [drive:\RootFolderWhereMusicWas] *.jpg /S
    That /S switch at the end will go thru all subdirectories. Might be basic for the oldskoolers, but surely someone else can benefit.
  3. #2793
    Apr 2008
    HI
    I want to install destinator 7 in my RR , i have found the skin .
    But i do not know where can i buy the software?
    Someone can help me.
    thank you
  4. #2794
    May 2007
    Just installed this, looks awesome!
    However, I've got some issues if anybody can help me sort them out:
    1. There is no logo in the middle. When I choose a layout in DFX Skin settings, it says "One moment please" and then nothing changes. What am I doing wrong? I just want to have a simple BMW image and a compass, like I did in DFX 2.0
    2. When going into "Wireless" it loads up a neat looking page that is supposed to show the available networks, signal strength, has a "Connect" button and everything. And then it overlays the windows network connections screen on top! Not sure why this is happening
    3. I must be blind, but I dont see an IG Menu button on the GPS screen. I am using IGuidance and there isn't even a way to enter a destination?
    4. I added a Youtube button, but when I click on it, nothing happens. The button is set to execute command "YT" or "YTV" I think. Is the plugin included with this skin or RR?
  5. #2795
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    That was going to be my next question. Glad you got it working.
  6. #2796
    Nov 2007
    PA
    Quote Originally Posted by Toxic0n View Post
    3. I must be blind, but I don't see an IG Menu button on the GPS screen. I am using IGuidance and there isn't even a way to enter a destination?
    Sounds like flash. Download and update latest shockwave and flash. Make sure you use fixflash provided with skin.
    As for Iguidance can you post a screen shot please?
  7. #2797
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Toggle the layout (from the first gps screen).
  8. #2798
    May 2007
    I have the latest flash but I haven't run fixflash.exe yet. Will give that a try and let you know.
    Quote Originally Posted by treetop777 View Post
    It has it in the horizontal layout but not the vertical which I use. It was there in the previous version. Any way to get it back?
  9. #2799
    Sep 2006
    War-Town, GA.
    Time to role-up your sleeve and edit the screen to your liking.
  10. #2800
    May 2008
    Does anyone know why my XM keeps changing channels in this skin? After I select a satition - for some reason the station selection skips down to the next channel after several seconds.
    And then the Next.
    And the next..
    and so on.
    Does anyone else have that issue?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
