Like Tree1Likes
Thread: DigitalFX 4.0
  1. #2881
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by stc256 View Post
    Does anyone know where I can get the DigitalFX Font.ttf file? The buttons at the bottom of the screen have numbers instead of icons but I can't find where this file is.
    Look in:
    \\Road Runner\skins\DigitalFX 4.0\Helper Files\
    My Fiero Build Thread
  2. #2882
    Nov 2008
    Look in:
    Do you mean DFXFont1.ttf ? I've tried creating a folder called fonts in the helper files dir and placing this file in it and the icons still don't show up.
  3. #2883
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Font dfx
    No, put the file dfx font in c:\windows\fonts folder .
  4. #2884
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Disk changer Question
    I have a question about the disk changer:
    my MP3 files are stored like this:
    <MP3folder><Autor1><albumx>
    <MP3folder><Autor2><albumx><albumy>
    and I can put all MP3 files to play using pressing and hold the "add album" button in the standard menu (leaving the selection in the "..")
    however, in the "database mode menu", I can´t "sel to disk" the entire MP3 folder only subfolders, unless if I put all folders inside another subfolder, like this:
    <MP3folder><redundance folder>
    <MP3folder><redundance folder><Autor1><albumx>
    <MP3folder><redundance folder><Autor2><albumx><albumy>
    then, I can" sel to disk" the "redundance folder" with the entire MP3 content...
    So, I wish to know if is possible to add the entire MP3 folder to a disk, in the disk changer???
    The reason that I am asking for that is that when I use the cd changer, I can easily switch between the full list or a specific cd, and when I switch back to the full list, it will start to play from the last music... and if I use the normal procedure, holding the ADD to folder, the playlist starts from the first song again....
    I hope that you understand my mess... hehehe
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  5. #2885
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    This probably isn't related to the skin, but I haven't been able to find any answers by searching for "pin" "security" "rr pin" "road runner pin" etc.
    I'm running DFX4, and I managed to get in a security locked out situation, and it's asking me for a pin number to unlock. I don't remember setting a pin, and I've tried my "normal" pins as well as 0000 #### **** etc.
    Is there a default pin # I can enter? How do I unlock this without knowing the pin?
    Thanks!
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
  6. #2886
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by cherrybomb View Post
    Thanks!
    C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Scripts\DFXLocker\DFXLock.ini
    You can enter a new pin here or use the default of 1234
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  7. #2887
    Apr 2005
    Southern Califorina
    Quote Originally Posted by fixerofallthing View Post
    Thank you!
    I coulda swore I tried 1234, but I must have been fat fingering it. It worked this morning now that I've calmed down, and gotten a sure answer on what the code is.
    Thanks again for tolerating my off topic request.
    Back to your regularly scheduled programming!
    Check out my blog.
  8. #2888
  9. #2889
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Iguidance DFX prob.
    I reported several months ago when 4 was released that Iguidance was doing some weird things in the skin. I haven't taken a trip in awhile but over the holiday went from Phoenix to LA. It gave me a lot of odd problems.
    1. I use horizontal layout. When going into "Guidance mode" it would self toggle the whole screen to a vertical layout and back to horizontal when done, as well as reloading the iguidance screen with white fade ins for no reason.
    2. Sometimes when going into Iguidance from the main menu it freezes the whole system. If I CTR ALT DEL and open the task manager it starts running as it should, without me doing anything but opening the task manager.
  10. #2890
    Sep 2007
    Thumbs up FB in DFX4
    Quote Originally Posted by Dougw133 View Post
    Not clog the thread up with pictures but here is my somewhat final Fusion Brain config. I matched the colors and made some new buttons to better match DFX4 in PS.
    Attachment 52736
    Hey Doug,
    Any chance you could give a cheatsheet / hints & tips / files for integrating the Fusion Brain as you have? I'm just about to attempt what you have posted (nice integration btw) and would really appreciate any help you could give. Sometimes the small stuff can take a while to figure out if you are starting from scratch...
    Thanks much,
    Dave
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
