Like Tree1Likes
Thread: DigitalFX 4.0
  1. #2931
    Nov 2008
    Quote Originally Posted by jbradshw View Post
    so today i was using my carpc, using rr and dfx 4.0, and i must have hit something funky on the screen as it locked it and showed the keypad to unlock.
    I've never used this feature, nor set it up. What's the default code to unlock it?
    1234
  2. #2932
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by JCGBIKE View Post
    HI,
    How can i do for run EXTERNAL APPS.
    Because mine does not run, when i select a command " NOTHINK"!!!!
    Look in the FAQ, you have to set it up.
  3. #2933
    Nov 2007
    Quote Originally Posted by treetop777 View Post
    The button is already setup in dfx, from the buttons you choose from, it don't say "iguidance", instead look for "GPS" or "navigation" and choose that one. When it goes back to the main menu it will say "iguidance"
    Maybe im not makin this clear enough. Ive tried every single GPS button and none of them are for iGuidance. I dunno if I accidentally deleted it in the button editor or what, but its not there. Using the button editor Ive selected one of the "unused" buttons to make my one. All I need to know is the proper path to put in the box circled in red, to make iguidance load and embed into RR with the proper skin. Can someone just copy and past what it says in your box? Thank you
  4. #2934
    May 2005
    Monterey, CA
    I didn't have to do that. I just setup igudiance in RRConfig and use the GPS button that was already there.
    If I get a chance I will check, but I am not sure which GPS button is the default on after install.
    FKA psptibby
  5. #2935
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by dfalk View Post
    Code:
    Load;$GpsScreen$;$GPSNAME$;$GPSPATH$;$GPSNAME$||ACTIVATE;iGuidance||SENDKEY;"{p}{p}
  6. #2936
    Nov 2007
    Code:
    That sorta works, It loads iGuidance into RR full screen but theres no icon to return to road runner. The only way to exit iGuidance is click the menu button and select exit. Then everything goes black and RR needs to be restarted. Any ideas?
  7. #2937
    Sep 2006
    War-Town, GA.
    If you just installed DFX, Delete it and re-install. IG works perfectly out-the- box, it shouldn't be giving you any problems..START OVER!
    If you are testing on a laptop or desktop with resolution other than 800X600, the button to exit full screen (IG) will apear off towards the top right of the monitor, not within the skin. And that's assuming the script to make it work isn't missing.
    So you have a decision to make. Keep troubleshooting a crippled skin or start over fresh.
    Ah, and make sure the path to IG (in RRconfig) is correct and the window name reads "iGuidance" (lil eye, big gee).
  8. #2938
    Constant Bitrate IonDokk's Avatar
    Michigan
    Quote Originally Posted by Machinehead View Post
    Update your RRmedia database from Blue's thread in the plugin subforum.
    Link: http://www.mp3car.com/vbulletin/rr-p...-released.html
    So I tryed that.... and it Froze again on the way home. Very frustrating
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
  9. #2939
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by IonDokk View Post
    Next step, delete the data base file from your music directory and rebuild the library from scratch.
  10. #2940
    May 2007
    Ok, so the logo in the center was not showing and no matter what I did, I could not get it to show. So I uninstalled RR and re-installed it in the default folder (c:\program files\Road Runner insead of c:\rr). I installed DFX 4.0 on top of that, ran fixflash.exe and now I'm can see the clock/logo, HOWEVER, I am having a different problem:
    The screen appears white and the buttons only come up once I click on them. I searched on here and found some replies saying my BACKGROUNDS path is invalid. I tried using RRconfig to set the background image path under the Skins tab to C:\program Files\Road Runner\BACKGROUNDS. That didn't work. There is not a BACKGROUNDs folder in the DFX4.0 skin folder . What can I do?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
