Like Tree1Likes
Thread: DigitalFX 4.0
  1. #2951
    Nov 2008
    John here is a picture of the new playlist screen. How can I get rid of the volume -, volume +, and mastermute images? Thanks...
  2. #2952
    Jul 2006
    If I remember correctly, those are in "botombuttons.txt". You'll probably end up adding the other buttons to your new playlist screen, and deleting the reference to "bottombuttons.txt" in your skin file.
  3. #2953
    Nov 2008
    Quote Originally Posted by barnyard View Post
    This is what happens if i delete the "bottombuttons.txt" in the skin file. Any other ideas?
  4. #2954
    Nov 2008
    Hey I figured it out. I deleted the following lines from "bottombuttons.txt", L,628,531,71,67,#DFX1R#,#DFX1G#,#DFX1B#,29,"Arial Black","=+","CENTER"
    L,526,516,71,67,#DFX1R#,#DFX1G#,#DFX1B#,40,"Arial Black","=-","CENTER"
    L,712,502,71,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER"
    L,599,504,71,67,#DFX1R#,#DFX1G#,#DFX1B#,65,"DFXFon t1","=4","CENTER" then renamed the file to "bottombuttons2.txt" then changed the menu.skin to load "bottombuttons2.txt" and wallah. Thanks for the help...
  5. #2955
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Looks good!
  6. #2956
    Nov 2008
    Thanks. Can anyone tell me though where the actual images are for the bottom buttons (the .png file)? I changed the code for the "exitmenu" (the button right next to menu) to a "searchfile" for searching through playlist but I need to change the actual image to a search image. I just don't know where the actual images are. Thanks...
  7. #2957
    Nov 2008
    nevermind, i just inserted "search" into the audio_playlist.png and deleted the code for the exitmenu, so now it says search.
  8. #2958
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by MGD View Post
    Hey John, just tryed your DIMMER Control. Isn't it going backwards? I mean if you want to DIMM more (as in darker), should'nt be the plus sign dimm more and the minus sign dimm less. I think the way it is now it is a brightness control, + brighter, - darker.
    Yea, I know that is a little strange, but the way it has to be the way RR sliders work. Think of it as adding less transparency This will be all new in the next release anyways, as Mitch was able to incorporate the dimming code directly into RR source, so no external program is needed to do the dimming.
    Quote Originally Posted by Cdeldridge View Post
    The bottom buttons are not "images" they are a custom font. This way when you change the font color in the skin, the "icons" change color as well throughout the skin.
    My Fiero Build Thread
  9. #2959
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I am using RR with the build in dimming function as I don't run any external programs for it. If you click the plus sign it gets lighter and clicking the minus sign makes it darker. No big deal for me as I just change the graphics for plus and minus.
  10. #2960
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If you look at any physical sliding dimmers, they always have the getting brighter bit as the plus or going up so what's the problem?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
