Thread: DigitalFX 4.0
  1. #2961
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by Enforcer View Post
    If you look at any physical sliding dimmers, they always have the getting brighter bit as the plus or going up so what's the problem?
    Then how come when you use the slider and push it UP the screen gets darker? So much for your theory. Like I said, no problem for me.
  2. #2962
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by MGD View Post
    I am using RR with the build in dimming function as I don't run any external programs for it. If you click the plus sign it gets lighter and clicking the minus sign makes it darker. No big deal for me as I just change the graphics for plus and minus.
    If you are using the dimmer slider in the DFX skin, as it was last released, it IS using an external app to do the dimming. Look in your system tray for a small round blue circle, that has the brightness symbol on it.
    Now that Mitch added to code to do this internally in RR, I have re-done the slider and skin to use the internal code, and it will be in the next release.
    My Fiero Build Thread
  3. #2963
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    because it is adding "More Darkness"
    Seriously, the dimmer uses an almost black layer over the top of Road Runner. When you press the slider up, you are increasing the visibility of that layer (Making the screen darker). When you move the slider down, you are decreasing the visibility of that layer, making the screen lighter.
  4. #2964
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    That I understand, as it is a dimmer control. Plus means more dimming. Then the house dimmers are "Brighters", push the slider up, more light.
  5. #2965
    May 2005
    Monterey, CA
    I recently switched to using the dimmer, but when I go to the Sirius screen, the list flickers. I think it happens because of ilist. I haven't disable ilist to verify yet. Anyone else get this. I am using DFX4 skin. I found that the dimmer seems to work better than gamma.
    FKA psptibby
  6. #2966
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by bay350z View Post
    It's a hardware issue. I have the same problem on my CarPC but not on my home computer.
  7. #2967
    May 2005
    Monterey, CA
    Quote Originally Posted by Machinehead View Post
    Really, that is odd. I would of never thought of that possibility. So ilist wouldn't affect it then.... Hmm I guess I can go back to gamma and tweak some more to see if i can get it darker.
    FKA psptibby
  8. #2968
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    the dimmer is awesome... but is there a way to make it time-sensitive so that it will only be darker at night? (kinda like gammacontrol)
  9. #2969
    May 2005
    Monterey, CA
    I thought it was. It seems to be for me. I only get the flicker issue at night which should be mean that is when the dimmer is enabled.
    FKA psptibby
  10. #2970
    Sep 2007
    Dallas,TX
    are you sure you aren't running gammacontrol or any other gamma related program in RR?
    im just curious because i figured the digitalfx dimmer was just an on-the-spot change and that it had no time setting.
    If that's wrong... I'll be a happy man!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
