Thread: DigitalFX 4.0
  1. #2971
    May 2006
    Chicago
    I thought this was kinda weird.
    Code:
    "MyApp20","Load;$GpsScreen$;$GPSNAME$;$GPSPATH$;$GPSNAME$||ACTIVATE;iGuidance||SENDKEY;"{p}{p}"
    What is the SENDKEY;"{p}{p}" for exactly?
    I removed it with seemingly no ill effects. I also tried to simply press p+p while in iGuidance but no effect. Is this for another external GPS app?
    I am the stig's cousin.
  2. #2972
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by utd09bry View Post
    are you sure you aren't running gammacontrol or any other gamma related program in RR?
    im just curious because i figured the digitalfx dimmer was just an on-the-spot change and that it had no time setting.
    If that's wrong... I'll be a happy man!
    It only flickers on iLists, which leads me to believe that it's hardware, drivers or directx.
  3. #2973
    Oct 2007
    Ot
    I love Johns new avatar.
    Hope you are feeling better and that your next avatar is a Red Ferrari
  4. #2974
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    it is mentioned in the docmentation for dimmer ,that it may flicker in some cases over ilists and app's , and it maybe down to a low powered or quality machine.
  5. #2975
    Jun 2007
    That's a cop out answer if I've ever heard one.
  6. #2976
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well mitch would'nt of put in there if it was'nt a problem would he, he could of said it all works hunky dory , and sod the lot of ya
    i'm only pointing out what was in black and white, to which most don't even read the documentation weather it comes with skins or rr.
  7. #2977
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    If you are using dimmer feature in XP with RR the inlaye or default video is all black and does not display either. Mitch is aware.
  8. #2978
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by carputer1 View Post
    Quote Originally Posted by Machinehead View Post
    That is actually the correct answer. I worked with Mitch when he was implementing this. On a machine with a "lesser" graphics card, you will see a flicker. (It does this on my laptop, but not on my Desktop system with the same EXACT install mirrored) It is not a problem with Road Runner, but in fact a problem with GDI and the way windows handles it. iLists and the dimmer overlay are both GDI, and they are fighting each other. Think of playing video on your system, and sometimes it bleeds through other windows, or you get a ghosting effect. Same thing if you try to screen capture a video, you cant with any standard screen capture program, as it is a "layer" of sorts. Bottom line is it is the way windows itself draws the video, as well as the GDI overlays that is the problem.
    My Fiero Build Thread
  9. #2979
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    ODB II Coming in the next release finally!!!!!
    It has been a long time coming, and many MANY thanks go out to Mezz64 for creating the RR plugin.
    I purchased a ELM 327 on ebay for around $25 shipped, so the hardware is certainly inexpensive! No car to test it on as of yet
    Here are a couple screen shots, and the plugin is functioning, as if it were not, all the fields would be empty, instead of containing 0's ect.
    I am working on flash gauges that will show Speed, RPM and Coolant temperature, that will match the gauges on the "Gauges" skin that uses GPS to display information.
  10. #2980
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    While trying to use latest RR, It changes from 32bit(color quality) to 8bit, when I exit out out of RR it switches back to 32bit. Did I forget to do something?
    EDIT: Never mind I found it.
    If you cant DODGE em, RAM em.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
