Thread: DigitalFX 4.0
  1. #2981
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Ramanator View Post
    While trying to use latest RR, It changes from 32bit(color quality) to 8bit, when I exit out out of RR it switches back to 32bit. Did I forget to do something?
    EDIT: Never mind I found it.
    Post the problem/solution just in case somebody else run into the same issue.
  2. #2982
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by treetop777 View Post
    You're right treetop, My monitor is set for 800*600*32*60, and under the "Run Road Runner at this Resolution" drop down window I was selecting 800*600*8*60, thus causing my screen to carp out.
    NOTE: FVI their is a lot to choose from, so be careful in your selection
    If you cant DODGE em, RAM em.
  3. #2983
    May 2005
    Monterey, CA
    Thats, great to see the ODBII plug in. I have had the hardware for awhile, but never used it since I had to switch to another app.
    FKA psptibby
  4. #2984
    May 2005
    Monterey, CA
    Quote Originally Posted by utd09bry View Post
    are you sure you aren't running gammacontrol or any other gamma related program in RR?
    im just curious because i figured the digitalfx dimmer was just an on-the-spot change and that it had no time setting.
    If that's wrong... I'll be a happy man!
    I am pretty sure, since I don't get flickering with gamma, only dimmer. I don't get the flicker problem during the day. I can check again. I might go back to gamma for now anyway.
    FKA psptibby
  5. #2985
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    i went with gamma settings because it seemed the easiest and only solution that was aware of time.
    my only problem is that while gamma works great, it really takes a lot of quality out of the picture. Sure, it's darker but it makes viewing angles and colors messed up in different ways. The dimmer overlay is great because it dims the screen equally and doesn't distort the colors in any way.
    Does anyone know how to make the dimmer time-sensitive? (if it isn't already...). If not, then I guess it is just a suggestion to add. I would love that feature
  6. #2986
    Nov 2008
    I made an additional playlist screen (a fullscreen playlist) but I can't seem to get the slider to work, i.e when I touch or click on the slider it doesn't move. Also when I touch or click on the screen where the songs are it won't highlight it or select it. Can anyone tell me what I need to do to get it to work? Thanks...
  7. #2987
    May 2005
    Monterey, CA
    It seems time sensitive to me. I only get the flickering problem at night, which only happens when the dimmer is on.
    FKA psptibby
  8. #2988
    Sep 2007
    [QUOTE=JohnWPB;1274248]
    >I am working on flash gauges that will show Speed, RPM and Coolant temperature, that will match the gauges on the "Gauges" skin that uses GPS to display information.
    John, first of all, THANK YOU for implementing OBDII!! Second, any chance you could design those gauges to display any (user chosen) of the OBD values instead of the three you mention? Showing gauges I don't already have in my car would be far more useful than duplicating physical gauges...
    Thresholds that change the gauge face color as a warning wouldn't be bad either! :-)
    Thanks for listening!
  9. #2989
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    @cdeldridge
    look in the old PL skin file and copy over the ilist line starts with il. thats for your i list.
    also the slider line the in editor the top 4 numbers are the postion of the slider and the next 4 are the touch area, just to start off make both sets of numbers the same , so the top set are the same as the 2nd set. should all work then
  10. #2990
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    [quote=flat6;1274384]
    Quote Originally Posted by JohnWPB View Post
    Unfortunately there is no way to make a "generic gauge". You have to set a bottom and top limit (0 to 8000 for the RMP, 0 to 300 or so for the Coolant temp for example, as well as having the correct scale of numbers on the gauge itself).
    I am by NO means a flash programmer, and am no good at it. I am usually able to take an existing gauge, and alter colors, background ect, and thats about it. The flash source code for most gauges can be found in the forums, and would need to be altered for each gauge. One things I just can NOT understand, is that Oil Pressure is not a standard PID. There is so much info avail through the OBDII, but not one of the most critcal ones.
    My Fiero Build Thread
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
