Page 30 of 557 FirstFirst ... 20212223242526272829303132333435363738394080130530 ... LastLast
Results 291 to 300 of 5570
Thread: DigitalFX 4.0
  1. #291
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    Quote Originally Posted by tigergibb View Post
    I'm not sure quite what you mean...
    Are you telling me that these 2 files:
    -C:/Program Files/Road Runner/skins/DigitalFX 3.0/menu.skin
    -C:/Program Files/Road Runner/skins/DigitalFX 3.0/menu2.skin
    need to overwrite the files here:
    C:/Program Files/Road Runner/skins/DigitalFX 3.0/Menus/Compass
    C:/Program Files/Road Runner/skins/DigitalFX 3.0/Menus/DigitalClock
    C:/Program Files/Road Runner/skins/DigitalFX 3.0/Menus/Photo
    C:/Program Files/Road Runner/skins/DigitalFX 3.0/Menus/SpinningLogo
    Wouldn't it be easier/better to just replace the files in
    so that it's easy to change if someone doesn't like it?
    yeah people can do whatever is easier for them, just making it aware again that those files are there. Like when I told someone how to get rid of the temps (didn't tell him to change all layout skin files), it will show the temps if he changes from like flash logo to stationary logo. just depends I guess if it's going to be a temporary mod or if it's a button change...some may not want their mods to change with the layout.
    EDIT* DON'T OVERWRITE them, just the lines you want to add/change. and I would suggest doing what kbreeden said, and just comment the original lines out.
  2. #292
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Found another thing that I mentioned while beta testing way way back that is STILL UNRESOLVED. ITs when you click on weather and there is no inet connection, it will not go back, press menu all day long and its just sitting there, have to shut it down hard.
  3. #293
    Oct 2007
    Sure, I posted it in my above post. I'm not sure if the font size is correct since I haven't tried it in the car yet, so maybe someone can let me know if it works/w double digits.
    Ok thanks for the picture, I have downloaded installed it but not yet tested one question though rather than modifiying the menu/menu2 skins is there a way to make it a selectable option via John's DFX setting page..
    Also maybe instead of Mi/H you can use MPH ? it would save you one character and leave more room for double digits?
  4. #294
    Oct 2007
    Houston
    Quote Originally Posted by digeratix View Post
    fyi:
    My install returns to Menu every time when I don't have a connection.
  5. #295
    Oct 2007
    Quote Originally Posted by PacketSniffer View Post
    fyi:
    I have mixed reactions with this sometimes it hangs the PC and sometimes it returns back to the menu. I do have Verizon EVDO usually connected at all times, but I have also noticed that even a stripped down zips.dat for location mapping causes the PC to hang.
  6. #296
    Sep 2007
    Ecko, no Im not clicking on the GPS weather. I am simply clicking on WEATHER on my menu, then its tries to dial an inet connection through my phone which at this time doesnt work.
    And you say
    "Knowing this would happen; why are you clicking on weather if you know you don't have an IC? DUH!"
    Its the principle. It should not happen. In a few days I may have it fixed to where it uses my phone for inet and it may not be an issue, but for now I dont want to bury the WEATHER button that I plan on using just so that some jerkoff doesnt press it and lock up my stuff making me have to cold reset.
    This is something that needs to be resolved.
    Much like going from XM to netradio doesnt mute the XM as it should.
    Are you saying that since I am aware of that that I should click on the MUSIC button first then go to inet radio?
    I dont think so pal. I dont want to have to be delicate with my actions for it to act as it should.
  7. #297
    Jun 2007
    Quote Originally Posted by BREWDOG52 View Post
    What ever dude you know what I'm talking about, I'm done trying to help people out here, thanks esko. I've got everything working that I need, I just mainly post here to help people out. but I'm done, AND YES THAT WAS A PROPER WAY TO RESPOND AFTER I ASKED YOU SEVERAL TIMES AND YOU CONTINUE TO DO IT, thanks for fixing your triple post that was almost 5 in a row but someone managed to squeeze in. but your now double posting to be a jerk, read like 3 posts back and the several times that I asked you to stop. It's not my skin/thread, you should show some respect to John and his thread though.
    Personally, I'd like for to continue to help and just ignore those that are aggravating you. If it were not for you I'd have given up on this skin.
    d
  8. #298
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Brew, take a chill pill, the way you are going you are going to get an infraction from the before he does.
  9. #299
    Nov 2006
    Anyone have an issue with Sirius skin? The scroller doesnt work for me. I have to use the Channel up/down buttons to move around.
  10. #300
    Jun 2002
    Virginia
    Quote Originally Posted by dmistry View Post
    Wow, I'm using the large (9MB) zips.dat and it is extremely dependable.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
