Can you show the entire contents of one of the playlists, if you have one that is just an album or so. The above line looks correct, so I do not see why it's not working.
Hi
I converted some itunes playlists with PlaylistConvert-0.0.5. This yields this format:
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\The Thin Ice.mp3
When I load the lists they only show one song. If I force a "reloadlist" command
with the skinner tool it loads properly.
I created a list with winamp and converted it and got the same results.
I've been searching (and learning) all day for a solution for this but I'm coming up empty.
Derek
My Fiero Build Thread
Hi John
Here you go. It does it on my laptop as well as my carputer.
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\The Happiest Days of our Li.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Another Brick in the Wall 1.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Mother.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Goodbye Blue Sky.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Empty Spaces.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Young Lust.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\One Of My Turns.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Don't Leave Me Now.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Another Brick in the Wall 2.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall (Disc 1)\Goodbye Cruel World.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Hey You.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Is There Anybody Out There.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Nobody Home.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Vera.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Bring the Boys Back Home.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Comfortably Numb.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\The Show Must Go On.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\In the Flesh.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Run Like Hell.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Waiting for the Worms.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Stop.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\The Trial.mp3
E:\My Documents\My Music\iTunes\iTunes Music\Pink Floyd\The Wall\Outside the Wall.mp3
Hmmm the playlist is fine. I am not sure what could cause it to load just a single song from the list. You say the same thing happens in Winamp when you run it stand alone right? If this is the case, there's a 99% chance it is not RR.
Check to make sure M3U's are associated with Winamp.
If all else fails, uninstall Winamp and try reinstalling it. use version 5.13 from oldversion.com.
Well looking at that list one file stands out.
has an invalid character in it.
it could be that it is the second one being picked up and because of the invalid charater winamp is throwing a wobbly on it and stops adding songs.
However I may be wrong.
Morning!
The playlists load properly in Winamp. When I load it in RR only one song appears in the list. Although when I play it all the songs play. If I force a reload it appears properly. Also if I change the sort order the list shows up.
If I create a playlist in winamp it loads properly. If I take the same list and run it through the converter and load it I get the same problem.
It does this with about ten playlists that I've tried so I'm not sure on that one either. Like I said above winamp loads it fine.
Thanks for the help.
Derek
Being trying to sort through this long post but I can not remember where I read about the missing signal meters in the sat radio.
I noticed that in sirius there is not a signal meter. What do I need to do to fix that?
Also what do I need to do for youtube to work? Does it need any files? Or just select the button? Seems like it hasn't worked for others.
Thanks.
FKA psptibby
i have been off the forums for a while now and I was checking in to see if there have been any new updates. I was in my car on Sunday and I was wondering if there was a way to make the full screen playlist because its hard to find a particular song when the artist/song has to scroll before you can see it. I think this would be a great addition to DFX, keep up the good work.
John, I just saw your avatar, what a sad day. I'm sorry man and I hope you are alright
The signal indicators have been fixed, and will be in the next release.
I compromised on the full screen playlistThere is now a "Toggle List" button that will toggle the way the playlist is displayed with each press:
- Artist - Title (Default)
- Title
- Title - Artist
Youtube has also been fixed. Elcamino had to change the plugin, as the youtube page had changed slightly, and broke the script.
On top of that I have made some other changes to the Youtube screen. Mostly cosmetic, updated lables and such. One other change is the addition of a "Favorites" button. When you press it, it will list the videos marked as favorites by any user. To change to your Youtube screen name, simply press and hold the favorites button, type in your username in the OSK and hit ok.
Yea, that was a sad day, 3 years worth of tinkering and work on that car here and there with the CarPC and the TONS of wires, modules, relays, sensors, cameras ect ect.... All gone in an instant![]()
