Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3001
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by bay350z View Post
    I noticed that in sirius there is not a signal meter. What do I need to do to fix that?
    There's a fix for the current version, search through the attachments for this thread by clicking on the paperclip next to the DFX thread in the RRSkins subforum.
  2. #3002
    May 2008
    Quote Originally Posted by JohnWPB View Post
    I compromised on the full screen playlist There is now a "Toggle List" button that will toggle the way the playlist is displayed with each press:
    - Artist - Title (Default)
    - Title
    - Title - Artist
    Youtube has also been fixed. Elcamino had to change the plugin, as the youtube page had changed slightly, and broke the script.
    On top of that I have made some other changes to the Youtube screen. Mostly cosmetic, updated lables and such. One other change is the addition of a "Favorites" button. When you press it, it will list the videos marked as favorites by any user. To change to your Youtube screen name, simply press and hold the favorites button, type in your username in the OSK and hit ok.
    Yea, that was a sad day, 3 years worth of tinkering and work on that car here and there with the CarPC and the TONS of wires, modules, relays, sensors, cameras ect ect.... All gone in an instant
    John - these changes are in the next release?
  3. #3003
    May 2007
    Quote Originally Posted by Toxic0n View Post
    I checked and the rr.ini file points to the C:\Program Files\Road Runner\BACKGROUNDS folder. There are also pictures in there. The issue still remains unresolved.
    One thing to point out, I copied the execbtl.ini for the DFX 4.0 from my last install as I made some custom changes there. Is there anything in that file that could still be pointing to the old folder? I took a quick look and didn't see anything...
    Just to post an update, I resolved my problem by going to DFx Skin settings and choosing a color theme. After that, everything worked perfectly.
  4. #3004
    May 2005
    Monterey, CA
    I was going through the different buttons and found a few that didn't work.
    Calendar - Comes up blank with the buttons on the bottom. What do I need?
    Engine - Future?
    Visulizations with sirius possible? Should work with line in winamp correct?
    Is there a internet radio button? I couldn't find it.
    I did search and didn't find much.
    Thanks again for a great well more then great skin.
    Also is there a way to get the help file online? DFX won't extract correctly on my desktop. Maybe you can post the help file on your site so I can read through it at work?
    Found help file attached to this forum.
    FKA psptibby
  5. #3005
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The help file is in DFX 4.0>helper files>Dfx 4.0.chm or something to that effect..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #3006
    May 2005
    Monterey, CA
    Quote Originally Posted by Machinehead View Post
    Thanks, never noticed that feature before.
    I also saw the attached help file, just what i was looking for. (Not sure if it is the current one thought)
    I take it is just a skin file that fixes it? I thought the images were missing....
    Edit:
    I just tired the downloaded help file and it doesn't work. Shows a IE page that it can't be displayed inside of the help window.
    Could just be this computer.
    FKA psptibby
  7. #3007
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Edit:
    There is a attachment for ODB does that work? I found my cable last night, and wanted to try it.
    For the help file, you need to right click, properties and under.....
    This file comes from a different computer... check the unlock property then it should run.
  8. #3008
    May 2005
    Monterey, CA
    Quote Originally Posted by MGD View Post
    Thanks, I forgot about that, stupid Windows.
    FKA psptibby
  9. #3009
    Jun 2007
    Yea, it's just a minor coding issue. I believe the file is "sat skins". There's only 1 version.
  10. #3010
    May 2005
    Monterey, CA
    Thumbs up
    Thanks, I found it. I will replace it in the car on my way home and see if that solves it.
    FKA psptibby
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
