Sure thing. Just extract and then copy and paste all of the files into the DigitalFX 4.0 folder (there are a few files that it will replace).
Well this is odd, I went to edit the menu.skin to add gps speed and heading to the main menu and it looks like it is already there. But I don't see it when RR is running. Any ideas why it isn't showing up?
Thanks, used it a lot with DFX3.
Edit:
Also i noticed motion lock doesn't work. It is enabled but I can still watch a video.
FKA psptibby
i think those are just there for the compass to work correctly, if you choose that as your menu layout. could be wrong though. I think I had tried removing one of those before (because I thought the same thing... where the heck is that label??) and it broke my compass indicator.
I replaced the sirius.skin file and they still don't show up.
From what i read putting usedx=false will disable iList completely? Even though it is true in the skin.ini?
In that case what is iliststatus value in the skin.ini?
I am trying to get my cpu usage down. Seems like it says close or at 100 a lot. Even with usedx=false it doesn't seem to help but after 5-10min it does go down.
FKA psptibby
1 in is in the actual menu skin. 1 is in the Indicators.txt file. I removed the one from the Menu skins, with no adverse effects.
But i would like the heading to work. I looked at my indicators file and it lists heading, but it just shows the gps symbol for the heading.
FKA psptibby
That is correct. John used it to show when RR was recieving valid GPS info, instead of the directions. All you have to do if you want the direction displayed instead, you'll have to replace the 8 ( N,NW,W,SW,S,SE,E,NE ) jpg files with an arror indicating the directiond of the name of the jpg file.
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
