Hi Guys,
This thread is WAY TOO long! Just spent 2 weeks making sure I read every post so I dont get flamed!!
OK, have latest RR installed, and DFX4.
Cant get CD Rip to work properly in the skin.
When I load CD Rip, the buttons on left side (Up, Remove Song, Down & Menu) all work, but the Reload CD, Rip 1, Rip All & CDDB buttons don't work, even tho you can 'select' them (they change when touched).
If I run CD Rip as stand alone program, it works. If I use the supplied skin and .skin file that comes with CD Rip, I can get it working in DFX4, but will only rip 1 CD then have to reboot before it can do another.
So, it APPEARS to be something in DFX4 causing the probs, and I suspect (but dont know enough about it), that has something to do with the exectbl.ini line, which is
"CDRIP","LOAD;cdrip.skin;RRCDRIP;RUNQ;$RRPath$\CDR ip\CDRip.exe"
As the .skin file looks OK.
Am using the version of CD Rip that was installed by either RR or DFX4.
Any ideas???
As I note, I want to rip to .MP3 format, but it appears the WMP only rips to .WMA format
LinkBack URL
About LinkBacks
