Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3281
    Nov 2008
    Quote Originally Posted by silvi4000 View Post
    check the weather.ini file. It will have some urls where the skin downloads the images. IIRC it will download them as a gif and then convert to flash. Easiest for you would be to look around your local tv station web site and see if there are any weather maps. Once you find one that uses gif images for animation, look at the page source and copy the image location and put it in your ini file
    Thanks for the reply, but I have already tried that, even if I just locate them to regular GIFs it will still load the same maps
  2. #3282
    Oct 2007
    Quote Originally Posted by joey7415963 View Post
    Is the loaded map showing the current date?
  3. #3283
    Oct 2007
    Quote Originally Posted by MGD View Post
    I have the same issue with my skin as well. Winamp is playing fine, changes songs from one to another but labels, iList, slider and albumart are frozen. If you click any button on the screen it will update everything and freeze again. All I have to do is restart RR and all is fine again. I think it is a Standby or Hibernation issue with the new release.
    BTW, screenrefresh=5
    So every 1/2 sec it should update.
    Made a post on the RR bug tracker
    http://www.mp3car.com/vbulletin/rr-b...bernation.html
    Please add your information on the issue
  4. #3284
    Nov 2008
    I think I've found what it is... in the weather_interactive.skin file there is a link to the weathermap.swf which is the USA map, i can't suss out how to embed a UK map into the swf though... or even if thats the right thing to do...
    any help would be greatly appriciated
    I have tried changing the lat/lon in the weather_interactive file and it still starts up on USA
    Anyone from the UK managed to suss this?
  5. #3285
    Oct 2007
    The interactive map pulls data from the internet from weather channel servers. If you drag the map to the UK you can actually see clouds so I guess it works for your region. If you have GPS, it should automatically center on your location when opening. If you dont have GPS, you can go to the weather skin a hardcode your coordinates
    Code:
    F,98,14,604,495,"WeatherMap.swf?&lat=xx.xx&long=xx.xx&viewPortWidth=600&viewPortHeight=400&initialWeatherLayerType=radar&initialZoomLevel=8&wxAnimateOnStart=true"
    The temperature and satellite maps are the ones that work by downloading the gif animations. Or that's how I understand it works
  6. #3286
    Nov 2008
    Code:
    That's the code I have already tried changing I tried it again and I still cannot get it working, it keeps starting in kansas somewhere!
    Have you had it working with yours?
  7. #3287
    Oct 2007
    Use this to test:
    http://image.weather.com/web/flash/F...teOnStart=true
    Once it does what you want it should be a matter of copying everything after the ?.
    Actually I just went and read the first post again and it says this
    Weather Live map that is dragable and zoomable. It will default to 1 of 3 things, to your GPS Location, to the Lat
    and Lon you set in the ini, and if neither is available, will default to the center of the U.S.
    So there should be an ini value you can change to re-center the map
  8. #3288
    Nov 2008
    Use this to test:
    Hmm thanks for the reply, I'm not too sure why its doing it, sounds like its defaulting like you said... but the ini file is in the folder with UK lat/lon but again these don't effect it even if they are changed
  9. #3289
    May 2008
    Is there a way to turn the mute button on the main menu into a ATT button, so it reduces the volume say 95%, but not totally mute it?
  10. #3290
    Nov 2008
    Could someone please post up their weather skin files and weather ini files please!
    I am trying to get my location sorted out on the radar and satellite and no matter what I change it doesn't change it!!!
    If someone has got their custom location sorted then please post your skin/ini files for me that way I can compare the two and find what I am doing wrong!
    Thanks for any help and thanks to silvi for trying
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
