Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3291
    Nov 2008
    Atlanta
    I cannot figure out why the indicators/bars at the bottom wireless manager skin are not working. i am using the windows wireless manager and the window is called wireless network connection. The top(embedded) part works fine. i have no file called custom_wifi_strength1 (or 0), which is referenced in the wirelesslist.skin . should I?
    I have searched this thread many times to no avail
  2. #3292
    Newbie japeeler's Avatar
    Nov 2007
    Jefferson, Texas
    Quote Originally Posted by joey7415963 View Post
    Hmm thanks for the reply, I'm not too sure why its doing it, sounds like its defaulting like you said... but the ini file is in the folder with UK lat/lon but again these don't effect it even if they are changed
    Joey.. I haD THE exact SAME ISSUE... I would change what was said to change, but it would just go back to it.. Soo.. I went and found EVERY Weather setting location I could find.. You have manually edit it.. I changed every location to my coords.. I finally got it working. Files I think Are involved:
    LiveWeatherInlucde.txt
    WeatherInteractive.skin
    WeatherLocation.txt
    Try those...
    JP
    -=- TruckPC Progress -=- 98% Complete -=-
    -=- 2006 Ford F-150 Screw 4x4 -=-
    @@@@@@@@@@ <-- Planning Phase
    @@@@@@@@@@ <-- Purchasing (Never End)
    @@@@@@@@@@ <-- Construction Phase
    @@@@@@@@@@ <-- Installation Phase
    My TruckPC WorkLog @ MP3Car.com
  3. #3293
    Nov 2008
    Quote Originally Posted by japeeler View Post
    WeatherLocation.txt
    Try those...
    JP
    Hmmmm.... Fairly sure that I've changed all those files already, I shall try it when I get back to my comp running RR.
    Thanks for your help!
  4. #3294
    Oct 2007
    Quote Originally Posted by silvi4000
    Quote Originally Posted by MGD
    I have the same issue with my skin as well. Winamp is playing fine, changes songs from one to another but labels, iList, slider and albumart are frozen. If you click any button on the screen it will update everything and freeze again. All I have to do is restart RR and all is fine again. I think it is a Standby or Hibernation issue with the new release.
    BTW, screenrefresh=5
    So every 1/2 sec it should update.
    So it is a RR issue and not DFx4 specific?
    I would probably say yes to that.
    The issue does not happen when using the BMV2 skin. Its not RR, must be the DFx4 skin causing the issue.
  5. #3295
    Raw Wave
    Jun 2002
    Virginia
    XM Trashes MP3 Playlist
    I have been experiencing this for a while, but have been too lazy to post it.
    If I'm listening to an MP3 playlist, then switch to XM to listen for a while, then switch back to Music (the MP3 playlist) the playlist I was listening to before switching to XM is gone. Instead, my playlist shows up as shown below. I must then reload the playlist.
    I don't recall seeing this issue mentioned before and my search didn't produce anything. Anybody know what might be going on?
  6. #3296
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by kbreeden View Post
    It's an issue with the winamp linein plugin. I've brought it up several times to TPB and haven't gotten any reasonable answers.
  7. #3297
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Machinehead View Post
    Thanks. I don't recall this happening in the RR/DFX setup I had a year or so ago. Hopefully, some of the brains around here can figure it out at some point.
  8. #3298
    Jun 2007
    Back a few versions ago that issue wouldn't occur but you could get it to auto start music. This was before Mitch got involved.
  9. #3299
    Nov 2008
    I've found the problem with the weather location that I have been experiencing!
    It's the LiveWeatherInclude.txt, it keeps changing the coordinates everytime I load RR!?!?!?
    Anyone got any soluions to this?
  10. #3300
    Oct 2007
    right click (or file menu) -> properties -> read only
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
