Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3311
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dougw133 View Post
    Just curiosity, I am debating on wether i want to mess with the RRgas myself or wait. I understand his qualms.
    Quote Originally Posted by Enforcer View Post
    Until John releases a new version with the skin files for RRGas, I have done a little exe to convert the old gaspricefinder skins to RRGas ones.
    post #2 of the RRgas thread.
    The new features however will still need to be added manually.
    *cough
  2. #3312
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    ..and the script works..
    It didn't change the icon labels for some reason (although it did in LSX) but that leaves only 6 labels to edit as opposed to 56!
  3. #3313
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by treetop777 View Post
    Think I know why that is.
    Will amend code and upload new version later on today/night
  4. #3314
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Wish that would have been out when I did all that manually.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  5. #3315
    Newbie taguy83's Avatar
    Mar 2008
    Roseville, MI
    Quote Originally Posted by JohnWPB View Post
    GPS has been working since version 2.0. You need to have a zips.dat file in your Road Runner root directory. (The skin installer installs it if it does not exist already) if that is in place, and you have a GPS signal, as well as RR configured for a GPS port (If you show satellites connected in the gauges screen), then tap the top display area on the gauges screen. The entire area is a hot spot to test the zips.dat LOCATE feature. If the cities and such fill with information, then it is working. You just need to add:
    localdatacaptureinterval=1
    To the RR.ini to update the information automatically. The "1" above means it will update the city labels every 1 minute.
    I got this working pretty easily, my only question is, everytime you open RR are you supposed to have to tap that area to get it to start, or is it supposed to automatically fill that in by itself? Because even after setting the 0 to 1 for the updates, it is blank until I tap it. I have been searching all over, can't seem to find an answer for it.
  6. #3316
    Jun 2006
    I'm having an issue with rating songs. The first time I build the song database I can rate as many songs as I like and it saves them just fine in the 3 Star, 4 Star, 5 Star playlists etc.
    However, if I reboot the computer and try rating them again they will no longer save. The original songs I rated are still rated and saved in the playlists but I can no longer rate new ones. Any idea what the problem might be?
    I just noticed this after about 2 months of usage whenI went to play my "5 Star playlist" and only like 10 songs were in it!
  7. #3317
    Mar 2006
    Pennsylvania
    Ok, how can I 'unload' the CD in the CD Changer screen?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #3318
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by PontiacGA View Post
    I jt keep one empty and switch to it...It "Unloads" it. It would be nice to vitually tunr the CD on and off...For instance if i am playing my Virtual Cd of my whole collection, and decide i want to browse up an album and play it, I can't revert back to the CD until I unload it and reload it.
  9. #3319
    Nov 2007
    PA
    Quote Originally Posted by taguy83 View Post
    I can't seem to get mine to stay either...It used so I don't know what has happened.
  10. #3320
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by jeremy480 View Post
    First, you are using DFX 4? I ask this because with this version, it uses my RRMedia plugin to manage the audio browsing and such to which no longer uses the old x star playlists to store the ratings and is now stored in the database. The easiest way to play the x rated songs, simply bring up the ratings screen and below the stars is the load x star playlist button.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
