Page 34 of 557 FirstFirst ... 24252627282930313233343536373839404142434484134534 ... LastLast
Results 331 to 340 of 5570
Thread: DigitalFX 4.0
  1. #331
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by treetop777 View Post
    ..with internet explorer only..
    That's what I meant.
    I'm testing Vista, I blame that.
  2. #332
    Aug 2007
    Quote Originally Posted by Zogg View Post
    Is this supposed to allow the connection info to show up in the lower area of the skin? I made the changes but the last one you show, the one for rr.ini, causes an error because of the $SKINPATH$ variable. I changed it to the actual path but it doesn't seem to do anything.
    The Windows wireless networks list shows up in the upper area for me, and did before these changes. Just wondering what is supposed to be different.
    Thanks,
    Z
    Zogg
    Yes it should fix the connection info. Not sure why your getting a error. Did you just put it at the end of your rr.ini? Mine looks like this...
    [Wirelees Fix]
    startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
    2004 Sport Trac PC Project.
  3. #333
    Newbie Freddieanto's Avatar
    Mar 2007
    Taylor, MI
    Quote Originally Posted by BREWDOG52 View Post
    Weird, I downloaded and unzipped with no problem, someone else mentioned it was corrupt though. I made a new zip, try this one out.
    http://www.fileden.com/files/2007/3/...nu%20ICONS.zip
    I did have problems, but this new zip file works.
    Fred
  4. #334
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Quote Originally Posted by japeeler View Post
    Anyone having issues with the "GASPRICES" area? I have my zip and such, but nothing loads into the Locations for each station. i can click on the gasprice.html file in the DFX dir, and get to msn-auto.com website, it shows the information, but I am not getting it to parse to the DFX/RR GasPrice screens... I got it to work a while back in DFX 2.5, but had to redo the skin/RR install, and never got it back working..
    man I LOVE this new way of changing your buttons and colors, everything in this version! Simply AMAZING work and help form the beta testers and this community...
    YOU ALL, YA'LL ROX! (yep, I am a Texan! YEEEEHAWWW!)
    I am having the same trouble.
  5. #335
    Feb 2008
    hi john,
    i found a little bug..
    in the execTBL file under "MyApp17" there is a double " in the line at the beginning and the end..
    that is the reason i could not get freedrive to run.
  6. #336
    Variable Bitrate redls1bird's Avatar
    Feb 2006
    Quote Originally Posted by redls1bird View Post
    Any one have a problem with their dvd/video screen controls staying up even after changing the screen?
    So no one else has this problem? Its happened on both 2.5 and 3.0. Any help?
    Car Pc progress meter:
    [-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  7. #337
    May 2005
    Mother Earth
    Quote Originally Posted by hardcoreracing View Post
    These are simple problems that I'm having, they are by no means a big deal. Just thought I'd mention it.
    I tried to load solitaire game today, all the other games work fine, but when I choose solitaire nothing loads.
    When I use scribble pad, when I start to drag a line across the screen it will mute the mp3 that is playing.
    Other than that, skin has been awesome!
    I just want to add aslo that solitare does not load for me. I checked the dfx games folder and the flash swf file for solitarie is not in there.. We may have to find a good one online and save the webpage then extract the flash.
    Quote Originally Posted by mnickolson View Post
    Zogg
    [Wirelees Fix]
    I tried it also. It did not work 100% . the labels did appear but then dfx3.0 closed down hard and never populated the top information. IT also spiked my 2.0ghz pc to 100% and the hour glass kept comming up like it was looking for another script or stuck in a loop.
    Ok I got the info working in the wireless screen. Here are the things that need to be changed.
    In the \DigitalFX 3.0\Scripts\WirelessList dir change Wirelessrr.exe to Wireless.exe
    In the ExecTBL.ini change "WirelessLabels","Runq;$SKINPATH$Scripts\wifi_man. exe" to "WirelessLabels","Run;$SKINPATH$Scripts\wifi_man.e xe"
    Add this line to your rr.ini startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
    Hope this helps.
    I just added to end of rr.ini and inside the exectbl.ini. Maybe since i used rrconfig the first time maybe i need to use that to edit the .ini s' since this time i just used notepad.
    edit--- EUREKA figured it out. Okay for us newbies using rrconfig.. do not cut and paste
    "WirelessLabels","Run;$SKINPATH$Scripts\wifi_man.e xe" or startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
    Nicholoson's fix figures we are smarter than the normal user, instead us newbies have to put the auctual skin path. example this is what i have in the rr config ini app for exectbl.ini
    "WirelessLabels","Run;"C:\Program Files\Road Runner\skins\DigitalFX 3.0\Scripts\wifi_man.exe"
    note i used the whole path not "$skinpath$" god i feel stupid for not thinking of it as a variable.Now put this in the ini extras. That is if you use the default paths.
    startcommand=RUN;C:\Program Files\Road Runner\skins\DigitalFX 3.0\Scripts\wifi_man.exe
    thank you Nicholoson for the instructions on fixing this..
    Okay now i still need to figure out why winamp wont freaking pause or mute when ig gives directions but will work perfectly in carwings skin when ig says directions..
    KIAs can have car pcs too..
  8. #338
    Jun 2002
    Virginia
    Quote Originally Posted by digeratix View Post
    That also raises yet another question... whats the Ter for? I was in a metro area once and it was lit up full bars for the first time ever.
    XM has a bunch of land based (terrestrial) towers around, mostly near big cities, in addition to the satellites. The Ter indicator will show when you're tapping into those.
  9. #339
    Jun 2002
    Virginia
    Quote Originally Posted by itech View Post
    But I still want to know if there is a way I can change the Favorite Icons to display my favorite channels
    One needs to edit XM_Favorites.skin to change the channel number for each button and edit XM_Favorites_On.png and XM_Favorites_Off.png to add the channel icons to the appropriate buttons. Once upon a time, John supplied the channel icons and the necessary PSD files, so that editing was pretty easy. I don't see them in this release, so don't know if he intends to make them available. I assume he does and has just forgotten to include them, but that will be up to him.
  10. #340
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by kbreeden View Post
    Add on note: Mainly because the buildings block the sat signal. XM has tons of towers to fill in the blank spots because of their geosynchronous satellites.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
