Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3441
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by tbird2340 View Post
    Good deal man.. I'm cooking with oil now..
    Just don't let that oil catch fire otherwise you'll be...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #3442
    Feb 2009
    -sorry wrong thread-
  3. #3443
    Constant Bitrate thewizard's Avatar
    Dec 2008
    This may be a stupid question, but I use iGo8 for my gps software. Is there some way that I can remove the buttons in the gps skin so that they are not in the way of the iGo buttons? The only one that I need to be there is the menu button. I love this skin and this is my only problem.
  4. #3444
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by thewizard View Post
    someone else might have a better answer, but i would say... you can make your own screen and embed that app into it. might be the easiest way
  5. #3445
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Just use whatever existing graphic works best and embed it.
  6. #3446
    Low Bitrate raggaman's Avatar
    Feb 2006
    Phoenix, AZ
    About the dimmer feature in DFX, it works but only darkens a portion of the screen. My GENERAL.INI file has the first four lines:
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=1024
    ShowHeight=768
    The 1024x768 is the screen resolution.
    What do I need to do so that the whole screen darkens and not the just the 800x600 portion of it?
    I searched but didnt find the answer.
    Oh why do I spend so much time and money on a technology that works only half the time? Is always a work in progress? Is never complete? I wonder.
  7. #3447
    Feb 2006
    Phoenix, AZ
    Nevermind, I figured it out. I just changed the darken.png in the GammaSlider folder under Scripts to 1024x768 from 800x600.
    Thread search keywords: gamma slider brightness size change
  8. #3448
    Dec 2008
    Thanks guys, I got it figured out now. I just started using Roadrunner recently so I am still learning the tweaks.
  9. #3449
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    Did some searching and not seeing any results on it, and not sure if this is DFX or RR issue. At minimum of after hibernation, everytime I go into the music screen and open the EQ, the bass and treble sliders keep getting reset to the bottom. I changed the mapmastervol= to 0 in rr.ini, so that isn't my problem.
    Ideas?
  10. #3450
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Quote Originally Posted by bemenaker;129625$4
    Ideas?
    do the sliders reset if you restart RR? load winamp by itself and see where the EQ sliders are set.
    not sure about hibernation, but everytime i change the eq settings and vol (not the mastervol) in RR it always resets when i restart. i realized it went back to winamp defaults. when i change the settings within winamp itself and then load up RR the settings hold.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
