Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3471
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    Ok, blue, I didn't realize that.
  2. #3472
    Oct 2007
    Quote Originally Posted by enforcer View Post
    i wonder what the ratio of posts (asking and answering questions about dfx) v (asking a question already answered, saying that questions has been answered, rr general questions and posts like silvi's and this one) is?
    1:4 maybe?
    > 9000
  3. #3473
    Low Bitrate nhra no 2's Avatar
    Aug 2006
    Aurora, IL
    To get the new horizontal gestures to work on the music screen, using Blue's database, just add these 2 lines anywhere in the exectbl.ini file in the skins folder:
    PHP Code:
    "ONCLFLICKL","RM_Browse",RM_Media.skin
    "ONCLFLICKR","RM_BACK",RM_Media.skin
    John,
    I have been trying to get horz. & vert. sliding to work on my carputer. It works on my main desktop with both DXF4 & Carwings. But I can not get it to work on my carputer. Any ideas? I am running the latest 3/1/09 exe. I have a freash install of RR as of early Dec. I even reinstalled DXF4. I have been also posting in the small update post, but it seems that it might be a skin problem & not a RR problem.
  4. #3474
    Apr 2008
    I cannot get my DFX to show up, Ive installed, deleted and reinstalled. Ive installed dfx to roadrunner, riderunner, in skins folder etc etc. I have searched this endless thread to see if anyone has had this problem and found nothing.
    It always reverts back to carwings dynamic. even tried deleting it and then RR would not open. Coming to you guys is my last resort of what else can I try to get this going. I apologize if im making an elementary mistake but rest assured I made every effort to remedy the issue before posting my problem.
  5. #3475
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by diomedes View Post
    simple question demands a simple answer.. did you set RR to load that skin and not Carwings (default) ? You need to run RRconfig and change the skin from there before launching RR. Since you didn't mention this, I am assuming you haven't tried this. If so, let us know... it might be a more serious problem.
  6. #3476
    Apr 2008
    Yes I have, I go the RR config and set the skins path to DFX and save the config and it never pulls up on RR. It always and constantly shows carwings. I going Nucking Futs!
  7. #3477
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    after you run the config, and before you start RR, is there a resume.ini still in the RR folder? Should be, as the config deletes it, and dbl check that the skinpath setting in the rr.ini does in fact say ...\Dfx...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #3478
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Diomedes,
    Make sure you change the Day and Night skins to the ones you want.
    ie: If you just change the Day skin to DFX and the Night skin is Carwings and it is Night Time, the Carwings skin will load after the DFX splash screen. Look in the Gamma/Dimmer section of RRConfig to see when night time is set to.
    ...JJG
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  9. #3479
    Apr 2008
    Holy crap!
    A tear, as I am getting closer... the resume.ini kept kicking to carwings, finally got it to load the intro to DFX befor it turns into a vertical
    bar... Which I read earlier I need to go into the rr.ini file and add fastmode=-1, I did that and nothing, does it go in one particular spot...
    Im so close, thanks guys
  10. #3480
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If you used the config, it defaults that setting to -1, which is GDI+ for just about all the newer skins now. I also had a typo and after you run the config, you should not have a resume.ini.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
