What did you find wrong with using cut & paste??
No, not true. RoadRunner will convert $skinpath$ to whatever you have it set to in the ini/config, before it executes the run cmd. Using the variable or the whole path will result in the same.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
I have done some work on being able to have a menu where you will be able to now turn on/off the plugins instead of editing the plugin.txt from within the skin.
I'll show it to John when he returns, while we are getting the media plugin intergrated in the next release.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
HD Radio will not work in DFX, it freezes up RR. I can get it to load in LSX, it also works with the stand alone program from Mitch.
Anybody have an idea what may be causing this. Am I missing a driver or something?
Before anyone says it yes I have checked the settings in the config file.
Niguhyrito,
Not sure why you think you have to dash me for trying to help and as to being smarter than the normal use, I am working on my first carpc and install. I just did a little reading on this site. It will work just as I posted it if your rr and skin install is normal and has no issues.
2004 Sport Trac PC Project.
First, I appreciate your help fixing this feature.
Using the command as you show with $SKINPATH$ I get this error:
AutoIt Error
Line -1:
Error: Variable must be of type "Object".
If I run the wifi_man.exe script outside of RR I get the same error window. So my problem appears to be somewhere else. I did find the wifi_man.ini file that had a Linksys adapter listed, which I don't use. I change it to my adapter's name but no joy.
I'm open to suggestions but reinstalling isn't an option right now as I'm going on a road trip in a few days.
Z
Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
The templates for the XM / Sirius favorites is in the DigitalFX 3.0/Helper Files/ folder. The icons are in Road Runner/XM. Just drag the icons onto the template in Photoshop or your favorite image folder. You will need to edit the XM Favorites skin to change the channel numbers to match your stations.
NOTE: The XM icons are in PNG format, and just renamed to .gif so RR will display them. If you attempt to load them into Photoshop, it will complain that the file can not be loaded, as it things it is a gif, and cant load it as such. Road Runner is smart enough to look at the header in the image file to determine what kind of image it actually is, believe it or not, Photoshop is not that smart![]()
My Fiero Build Thread
You do not need the wifi_man.ini in the new version.
Edit---
Here is the link and a quote from that page.
http://www.mp3car.com/vbulletin/rr-p...i-manager.html
[QUOTE=Angelus;1139816]Hi EL CAMINO,
I can't seem to get this plug-in working, I've done the following
put wifi_man.exe and the wifi_man.ini in the roadrunner folder
changed the setting in wifi_man.ini to Wireless_G PCI Adaptor the name given by the device manager
added the following line to rr.ini
startcommand=RUN;$rrpath$wifi_man.exe
added the following line to execTBL
"WIRELESS","LOAD;wireless.skin||SETTOPMOST;RR;TRUE ||RUNQW;$SKINPATH$\wireless.exe;Wireless Network Connection||GETFOCUS"
and put the skin file in the road runner skin file
The skin will launch correctly but the wireless network connection doesn't appear either infront of road runner or behind.
Have I set something up incorrectly or can you give me any ideas??
thanks in advance,
Pete[/QUOTE
Are you using a stripped down version of XP like NLite or something, the solitaire skin embeds windows solitaire, which it sounds like you have stripped out. The other thing could be you do not have windows installed to c:\
1) I did not set that plugin to be used as default on purpose. Most people do not have the album art embedded in the MP3's. If this is the case, you will see the album art flash (showing the one in the folder) and then disappear as it trys to display the one in the MP3 file.
2) RREarth is not complete, I was messing with trying to get it working and never 100% completed it.
3) There is no way to display the cover art in the album art browser screen using embedded images in the mp3's. This holds true for the one in DFX, as well as the flash album art browser. Both require images to be in each folder.
Was there any luck with embedding My Bluetooth Places? I have looked around everywhere on the 2.5 thread and this one and hadn't been able to find anything. Thanks
