Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3511
    Low Bitrate raggaman's Avatar
    Feb 2006
    Phoenix, AZ
    Quote Originally Posted by silvi4000 View Post
    So far nothing I have tried so far have fixed the "return from hibernation freeze".
    I might have to revert to an older version just to get rid of this issue. Previous versions work perfectly across hibernation cycles. Now that I have all my USB devices working perfectly across hibernation DFx4 is having this problem.
    Can more people test if DFx4 freezes values after resuming from hibernation?
    as POSTED :2/22/09 3405
    Silvi, I don't know if you are still having the freeze issue after hibernating or not, but wanted to tell you that I have the same problem. In DFX 3 i used hibernate all the time as it is 10 times faster than a cold boot. As others (and you) have already summized, the issue is probably due to non initialization of the various plugins associated with DFX 4. I am trying to figure out a solution. Let me know if you found something.
    Oh why do I spend so much time and money on a technology that works only half the time? Is always a work in progress? Is never complete? I wonder.
  2. #3512
    Oct 2007
    Quote Originally Posted by raggaman View Post
    I tried everything but formatting the carpc (reinstalled everything RR related, updated drivers, unplugged devices) . I know the problem is the skin but I cant find what specifically is causing the issue. Somewhere a process/loop responsible for updating the variables is not working after resume.
    Im just closing and reopening RR after resuming from hibernation as a workaround but that beats the purpose of hibernating in the first place.
    Let me know if you need me to try/test anything but I dont think Im going to spend any more time trying to figure out this issue. If a format is needed to fix it I migth as well upgrade to linux
  3. #3513
    Jan 2008
    Code from Command Line
    Any help is much appreciated!!!
    I have a program (MyMobiler.exe), I made my own skin to start the program, however when the program starts it is minimized in the taskbar. The only way to open it in a window is to right click on it and select open window, or through the command prompt execute it by giiving the command "mymobiler.exe -open". My execute line in "exectbl.ini" is "MyApp07","RUN;E:\My Mobile\MyMobiler\MyMobiler.EXE"... Is there any way i can execute the -open command from within the skin??
    Thanks guys
  4. #3514
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    try this, xxxx is your skin name
    "LOAD;xxx.skin;Phone;C:\PUT MYMOBILER.EXE PATH HERE\MyMobiler.exe -open;!My Mobiler"
  5. #3515
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by carputer1 View Post
    Think it might be
    "LOAD;xxx.skin;Phone;C:\PUT MYMOBILER.EXE PATH HERE\MyMobiler.exe|-open;!My Mobiler"
    or remove the hypen altogether
  6. #3516
    Jan 2008
    Quote Originally Posted by Enforcer View Post
    Think it might be
    Thanks that worked perfect, one more thing. I put the main volume and next and prev track buttons on my skin, however when i use one of them the mymobiler program disappears behind RR, here is my skin file. How do i get the ACTIVATE command in the MUTE PREV AND NEXT lines???
    RoadRunner Skin
    RRScreen Phone
    B,2,89,98,084,"PREV",
    INC,DFX_Font_Color.txt
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B24,442,338,98,83,"ACTIVATE;!My Mobiler||SENDKEY;{DOWN}",
    B23,445,149,90,80,"ACTIVATE;!My Mobiler||SENDKEY;{UP}",
    B,554,49,231,56,"PLAY",@STOP||PLAY@
    B,2,2,98,084,"NEXT",
    B26,2,518,103,78,"CLOSE","Exit"
    B10,548,397,248,69,"ACTIVATE;!My Mobiler||SENDKEY;{ENTER}",
    B08,337,529,218,67,"ACTIVATE;!My Mobiler||SENDKEY;{F4}",
    B07,106,530,206,65,"ACTIVATE;!My Mobiler||SENDKEY;{F3}",
    B59,443,250,91,81,"APPOSK",""
    B,435,433,106,90,"ACTIVATE;!My Mobiler||SENDKEY;{F7}","volume-"
    B,446,54,91,81,"ACTIVATE;!My Mobiler||SENDKEY;{F6}","volume+"
    /,B03,2,178,98,082,"ACTIVATE;!My Mobiler||SENDKEY;{RIGHT}",""
    B03,2,173,98,082,"VOL+",
    B04,3,258,97,083,"VOL-",
    /,B04,2,265,97,083,"ACTIVATE;!My Mobiler||SENDKEY;{LEFT}",""
    B11,550,109,079,72,“ACTIVATE;!My Mobiler||SENDKEY;{1}",""
    B12,631,109,080,69,“ACTIVATE;!My Mobiler||SENDKEY;2",""
    B13,712,113,077,67,“ACTIVATE;!My Mobiler||SENDKEY;{3}",""
    B06,2,438,98,083,"ACTIVATE;!My Mobiler||SENDKEY;{F2}",
    B05,2,344,98,083,"MASTERMUTE",""
    B20,552,321,079,70,"ACTIVATE;!My Mobiler||SENDKEY;{F8}",
    B25,557,533,238,61,"ACTIVATE;!My Mobiler||SENDKEY;{F11}",""
    B14,552,181,079,65,"ACTIVATE;!My Mobiler||SENDKEY;4",""
    B15,634,181,079,65,"ACTIVATE;!My Mobiler||SENDKEY;{5}",""
    B16,713,183,077,64,"ACTIVATE;!My Mobiler||SENDKEY;{6}",""
    B17,551,254,079,63,"ACTIVATE;!My Mobiler||SENDKEY;{7}",""
    B18,632,251,079,66,"ACTIVATE;!My Mobiler||SENDKEY;{8}",""
    B19,712,250,077,68,"ACTIVATE;!My Mobiler||SENDKEY;{9}",""
    B09,551,468,247,58,"ACTIVATE;!My Mobiler||SENDKEY;{F12}",""
    B21,631,322,079,67,"ACTIVATE;!My Mobiler||SENDKEY;(0)",""
    B22,713,320,077,69,"ACTIVATE;!My Mobiler||SENDKEY;{F9}",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L55,27,79,56,70,#DFX1R#,#DFX1G#,#DFX1B#,60,"DFXFon t1","=1",""
    L55,31,-14,47,77,#DFX1R#,#DFX1G#,#DFX1B#,71,"DFXFont1","=3 ",""
    L55,715,16,64,28,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"VOLUME","CENTER"
    L55,500,15,100,30,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"REMAININGTRACKTIME","CENTER"
    L03,112,10,380,35,#DFX1R#,#DFX1G#,#DFX1B#,18,#DFXF ONT#,"/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
    L,0,155,67,93,#DFX1R#,#DFX1G#,#DFX1B#,71,"DFXFont1 ","=4","CENTER"
    L,0,328,67,93,#DFX1R#,#DFX1G#,#DFX1B#,71,"DFXFont1 ","=4","CENTER"
    L,0,237,67,93,#DFX1R#,#DFX1G#,#DFX1B#,71,"DFXFont1 ","=4","CENTER"
    L,8,544,83,36,#DFX1R#,#DFX1G#,#DFX1B#,19,#DFXFont# ,"=MENU","CENTER"
    L,570,482,197,34,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Home","Center"
    L,569,548,197,33,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Screen Off","Center"
    L,716,335,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=#","Center"
    L,636,336,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=0","Center"
    L,557,342,71,44,#DFX1R#,#DFX1G#,#DFX1B#,40,#DFXFon t#,"=*","Center"
    L,716,261,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=9","Center"
    L,636,262,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=8","Center"
    L,555,263,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=7","Center"
    L,716,193,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=6","Center"
    L,636,194,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=5","Center"
    L,556,193,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=4","Center"
    L,716,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=3","Center"
    L,636,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=2","Center"
    L,555,123,71,49,#DFX1R#,#DFX1G#,#DFX1B#,32,#DFXFon t#,"=1","Center"
    L,570,413,197,40,#DFX1R#,#DFX1G#,#DFX1B#,26,#DFXFo nt#,"=Enter","Center"
    L,445,270,88,32,#DFX1R#,#DFX1G#,#DFX1B#,20,#DFXFon t#,"=OSK","Center"
    /,L,10,122,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFon t #,"=PREV","Center"
    L,45,196,39,29,#DFX1R#,#DFX1G#,#DFX1B#,30,#DFXFont #,"=+","Center"
    L,51,260,28,12,#DFX1R#,#DFX1G#,#DFX1B#,50,#DFXFont #,"=-","Center"
    L,51,384,34,20,#DFX1R#,#DFX1G#,#DFX1B#,10,#DFXFont #,"=MUTE","Center"
    /, L,10,392,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=1","Center"
    L,10,463,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Contacts","Center"
    /, L,10,477,88,20,#DFX1R#,#DFX1G#,#DFX1B#,13,#DFXFont #,"=2","Center"
    L,640,21,73,20,#DFX1R#,#DFX1G#,#DFX1B#,12,#DFXFont #,"=VOLUME","Center"
    L,445,80,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFont #,"=Vol UP","Center"
    L,464,179,48,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFon t #,"=^","CENTER"
    L55,648,15,47,77,#DFX1R#,#DFX1G#,#DFX1B#,71,"DFXFo nt1","=2",""
    /,L,467,87,46,31,#DFX1R#,#DFX1G#,#DFX1B#,35,#DFXFon t #,"=^","CENTER"
    L,462,366,50,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFon t #,"=V","CENTER"
    L,445,463,88,20,#DFX1R#,#DFX1G#,#DFX1B#,15,#DFXFon t #,"=Vol DN","Center"
    /,L,466,471,47,36,#DFX1R#,#DFX1G#,#DFX1B#,21,#DFXFo nt #,"=V","CENTER"
    /, A, x, y, w, h, color;RGB
    /, I, x, y, w, h, Code;INDICATORCODES
    /, Y, Back Slider file path
    Y01,"\volume_slider\volume_*.jpg"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    END
  7. #3517
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well, you have no Application area to embed your program, so all you are doing is running the program not embedding it.
    you need a line like so
    A,10,10,100,100
    you will to change the numbers to get the application to show where you want it
  8. #3518
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    After a recent update of "Ride Runner" a few things seem to be on the fritz again. The wireless connection screen is not showing any data for the status of the connection on the bottom even though I have a connection. I remember there being a fix for this LONG ago, and I have been searhcing around. Anyone remember how this is fixed? Thanks.
  9. #3519
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by treetop777 View Post
    286
    thanks
    Quote Originally Posted by JohnWPB View Post
    You can just copy the speedo.swf into the 3DLogo's directory. It will then show up as an option when you browse the 3D logo's in the list. I am pretty sure it is already in there from the last release though.... not 100% sure, but 90% at least
    I don´t find it, but don´t worry, I developed a new custom screen to show the current speed and some other information.
    How can I put an .png image on the screen and change it without restart the RR?
    I know that it is possible because it happens with the menu icons, but I don´t know how to do that.
    please, help me GODS OF SKINS
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  10. #3520
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by Dougw133 View Post
    After the last ride runner update, the music visualization don´t comes in the right place as well.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
