Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3521
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by marteline View Post
    thanks
    I donīt find it, but donīt worry, I developed a new custom screen to show the current speed and some other information.
    How can I put an .png image on the screen and change it without restart the RR?
    I know that it is possible because it happens with the menu icons, but I donīt know how to do that.
    please, help me GODS OF SKINS
    You use a indicator pointing to a file to show.
    I,xxxx,xxxx,xxx,xxx,"File;<path to file>"
    You can use a var for the file path and just set/change the var and the indicator will update
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #3522
    Nov 2008
    I was wondering if someone can tell me what code to use if I want to make a volume slider in the skin editor for the DFX sking, so i can quickly turn the volume up and down? I tried using this code: "VOL;<AUDIO LINE>" but it doesn't seem to work. And this is what I used for the pointer file path: "Sliders\Pointer.png". Any help would be great. Thanks....
  3. #3523
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    There a really great example in the mixer screen...
    S13,62,144,55,260,56,102,73,349,V,01,"EQ.PNG",25," MASTER","Master"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #3524
    Nov 2008
    Yeah thanks that will work. I just decided to make all the volume buttons go to the mixer screen so I can adjust the volume there.
  5. #3525
    May 2007
    hi, i saw someone else mention it, and didnt see any answers, how can i get map monkey working with this skin? ive tried but had no luck yet
  6. #3526
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    It seems to me I am now having several weird issues after ride runner update. Another to add to my wifi skin not showing status, is that when in Standard Browser mode ONLY, if I double click a song to play it, the browser mode changes to database style everytime. What could be causing this?
  7. #3527
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Has anyone found a fix for freefone not embedding properly? Currently, when i click phone,it brings up the app, but i lose RR, and i cant get it to come back without closing it through the taskbar and then re-opening it.
    Also, where is the config for freefone? I had it working on my last install, but i had to start over when my hdd crapped the bed. Anyone who is using freefone successfully, what drivers are you using?
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  8. #3528
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    if it's not embedding properly then you probably have the window name wrong.
    Freefone doesn't need any special drivers, just the correct drivers for your bluetooth connection.
    The config file should be in the root of the freefone folder
  9. #3529
    Jul 2006
    so whats happening with this Skin. Now updates since Jul 2008??
    Has the project reached it end?
  10. #3530
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, John is very busy and with the previous events(mother passing, car accident,ect) motivation to get an update out is lower on the priority list...
    I have volunteered to update all the supporting AutoIt scrips to use the "RideRunner.exe" process name as well to keep it current with the name change, but can't do so until John get back from China. I have most of the source'e for the scripts but not all.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
