Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3531
    May 2005
    Monterey, CA
    Quick question, is it possible to integrate Garmin with this skin? I thought about switching from IGuidiance to Garmin.
    Thanks.
    FKA psptibby
  2. #3532
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Quote Originally Posted by Enforcer View Post
    if it's not embedding properly then you probably have the window name wrong.
    Freefone doesn't need any special drivers, just the correct drivers for your bluetooth connection.
    The config file should be in the root of the freefone folder
    It embeds properly on this install with DFX 3.0 no issues, but nothing with 4.0. i just lose RR at that point.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  3. #3533
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Blue, I see you mentioned something about the code for Ride Runner and DFX 4. I have asked a few questions on here recently without any acknowledgment. To make a short list, here is what I have run into since updating to Ride runner.
    1.)When playing a song from browser in standard mode, it switches to Database even when I have Standard only selected.
    2.)GPS weather no longer works. It will load the maps (sat,radar etc..) in correctl gps location however will not pull a forecast by way of gps.
    3.)When loading a virtual CD, the volume zero's when it starts playing. This only happens with virtual CD's.
    4.)No wireless signal info on the wireless screen anymore.
    That's just a few problems I immediately noticed.
    If it is something I can fix on my end great! If not, and it has to do with new code etc.. that needs to be fixed in the future than no problem.
    I am just curious if it is something I could have screwed up or it is to do with the update. Any idea? Thanks...
  4. #3534
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Forgive me if it has been mentioned(can't believe I just said that!)... The only way to know is if using a fresh instace of both, starting with an older rr install and a working skin, then do an update to the newer RR version and go from there...
    There's just never enought time...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #3535
    Nov 2007
    PA
    Well that's what I did..I have been updating RR since 2006. DFX 4 was already installed..
    I guess I'll try to wipe them all clean off the machine and start with scratch. Thanks.
  6. #3536
    Nov 2007
    PA
    Just completely clean installed the new Riderunner Binary, Digital FX, Latest RR Media. All problems I explained above still persist. Thanks for the suggestions
  7. #3537
    Mar 2009
    Sorry for my english.
    Thanks for this wonderfull skin for me is the better.
    I need to ghange logo3D but i don't find button, somebody help me please!
  8. #3538
    Nov 2007
    PA
    Quote Originally Posted by titamarco View Post
    go to "settings" on the second page of the skin by hitting menu to get there..you'll se "digital fx settings" and there will be options for fonts, colors etc... make sure you select the proper "menu layout" and then change your center logo to whatever you want.
  9. #3539
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If I can find a few minutes, I'll use a fresh everything and see if I see any of those issues..
    1.)After you have P&H'd the browse btn selected the std one, check your skin.ini file and dbl chk that the setting is getting saved properly "BROWSINGMODE=0"
    2.) I'd have to check on this, can't remember if this was always this way??
    3.) This problem has been reported be some users, and that part of the code in RRMedia has been reworked.
    4.) I don't think that I have ever had any of that bottom info...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #3540
    Nov 2007
    PA
    Thanks for the suggestions and input. Yes weather used to load the local forecast by GPS location if you desired.
    At one point the status did work. There was missing code or an erro on a simple skin file or ini file. I can't remember, i thought it got fixed for some reason. I'll track the fix down.
    I will check when I got off work about the "BROWSINGMODE=0"..
    Again, thank you very much.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
