Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3661
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by junhe View Post
    i try to play the rmvb video file using the Video, but it sometimes pop up the error said " media player classic cannot render some of the pins in the graph,you may not have the needed codecs or filter installed on the system"
    looks like as media player says, "you may not have the needed codecs or filter installed on the system"...
    try to install the following codecs:
    Real alternative; (this one is for rmvb)
    ffdshow.
    they will solve your problem.
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  2. #3662
    May 2009
    i play with the MPC without problem, but when running the video in DFX, it show this error.
  3. #3663
    May 2009
    the manage playlist function not working,i create the new playlist, and it show saved, but i see nothing at the playlist
  4. #3664
    Raw Wave
    Jun 2002
    Virginia
    On page 1 of the music section of RRConfig make sure ".m3u" (no quotes) is included in the Audio File Types box.
  5. #3665
    May 2009
    Quote Originally Posted by kbreeden View Post
    i included d, but how to add new?
    i click on "Manage Playlist" then it is nothing there,
    even i click "New" and Enter, it show playlist saved.
    but it is nothing there also
  6. #3666
    Raw Wave
    Jun 2002
    Virginia
    Did you create a folder for playlists on your computer and then point to it in Page 1 of the music settings in RRConfig?
  7. #3667
    May 2009
    got it. thanks!!!
    any ppl noe how to play RMVB file?
  8. #3668
    Low Bitrate Flaring_Afro's Avatar
    Sep 2008
    VA
    ^ the answer is in the first post on this page.
  9. #3669
    May 2009
    i tried, it hanged after play 2 second.
  10. #3670
    Jan 2008
    Quote Originally Posted by Flaring_Afro View Post
    this didnt happen originally, but the in the main menu the only (bottom) button that looks right is the far left one. all others have numbers on them instead of the play/pause symbols etc. same thing happens in music player and in video half of them (same ones like play) dont show and have numbers too.
    i tried going back to restore point, reinstalling rr, fx, flash, divx, winamp, everything i had installed and it still does this. how could this be? at one point it worked fine then nothing. also, all firewalls are disabled.
    EDIT: pic
    alright, I have the exact same problem.
    I have found the solution on the first page--that I need to reinstall the digitalfx font from the helper files, I found the font, but can't figure out how to install it. I tried copying the font over, but it still doesn't work. what am I doing wrong?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 01:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 10:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 03:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 02:19 PM
