Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3691
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Analog clock question:
    I recently loaded up one of the pre configured user settings for the skin. I reall liked the orange Analog style clock. Today I noticed that when my system resumes from standby the clock has stopped.Anyway to fix/change this? thanks.
  2. #3692
    Newbie Kadyroff's Avatar
    Sep 2007
    Moscow, Russia
    anyone, please advise on how motionlock should actually lock my video! So far, I can easily watch video while I'm driving, and I want it locked, like any OEM system.
    Does it depend on the speed? I mean, is it supposed to lock video upon reaching some specific speed? I have my GPS working, and the Gauges screen shows all the info - speed, satellites etc. I checked plugins.txt and "X,Motionlock" is there.
    project progress:
    Planning.......[--------X-] – 90%
    Parts............[-------X--] – 80%
    Fabrication....[------X---] – 75%
    Installation...[-------X--] – 80%
    Worklog
  3. #3693
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Make sure that the MotionLock.dll file is registered, also check the motionlock.ini for proper settings, both of which should be in your RR root folder.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #3694
    Sep 2007
    Moscow, Russia
    thanx, Blue!
    project progress:
    Worklog
  5. #3695
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    quick question:
    how I set a temperature gauge to work? As I see it just uses the RR temp, and I need it to work with the speedfan info (cpu temp)
    something like that: "SETVARBYCODE;TEMP1;SFT0" ???
    I can´t figure out how to make it work....
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  6. #3696
    Nov 2007
    PA
    Quote Originally Posted by marteline View Post
    quick question:
    Pretty Sure it's detailed in the help file.
  7. #3697
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by Dougw133 View Post
    I don´t think so, anyway, guino give me some tips, and I edit the flash gauge to show the Speedfan info instead the RR temp1.
    If anyone needs a flash gauge that shows the speedfan SFT0 information, just send me a PM.
  8. #3698
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    SHARE! SHARE!
  9. #3699
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Just post it here please. Thanks!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  10. #3700
    Nov 2007
    Hi all. I just solved a problem I was having with the audio browser with some help at the RideRunner release sticky. Thought it would be helpful to post here since it was fixed with a skin change. I can't imagine I'm the only person with this problem (although possibly the only person who feels this is difficult enough to post a fix).
    My issue can be seen in the image here.
    Notice the folder icons in the list. Also, I was no longer able to "throw" the directory list. Basically it was a problem with ilists.
    First issue, DFX4.0 uses RM_Media.skin as the audio browser. not Audio_Browser.skin. Took 15 minutes to notice that
    Anyway, it was an issue with the Custom List used in the RM_Media.skin. The command format has changed slightly. these were the changes made.
    Old:
    SC,55,140,381,373,#DFX1R#,#DFX1G#,#DFX1B#,255,128, 0,255,255,255,0,0,0,,20,"Arial"
    Fix
    SC,55,140,381,373,#DFX1R#,#DFX1G#,#DFX1B#,0,0,0,#D FX1B#,255,255,0,0,0,TRUE,20,"Arial Narrow:B"
    Some of these changes are aesthetic but the big thing to note is the parameters section of the command (0,0,0) moved. This is well documented in the Skin Commands file so it just took a little hunting.
    Hope this helps someone!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
