Page 38 of 557 FirstFirst ... 28293031323334353637383940414243444546474888138538 ... LastLast
Results 371 to 380 of 5570
Thread: DigitalFX 4.0
  1. #371
    Dec 2006
    Amazing!
    Wow John. You've out done yourself this time. 3rd contribution on it's way (hint hint everyone else)
    With the new version, I decided to take the opportunity to rebuild everything as I was having a hibernate issue. Before I did that, I tried 3.0 and didn't see any problems.
    After rebuilding XP and installing RR, Winamp and 3.0 I've run into a problem. A search has not yielded a solution.
    When I click on change skin color, I get a black and white screen. The color wheels for screen and font are not there. I tried just clicking around in the general area to see if they were there but invisible. Nothing happened. Yes, I went and downloaded the flash player from the first FAQ.
    Thanks again John for your long hours of effort.
    Kevin
  2. #372
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by CoryF View Post
    Thanks for the fast responce John
    John I see your using a Fusion Brain, I was just wondering if you could post how you have it set up in the skin. I just got the Fusion Brain but dont really know where to start on embedding it into the skin.
    THANKS
    I have honestly not even had a chance to do anything with the Fusion Brain as of yet. I do, down the road, plan to control the door locks and windows with it.
    Quote Originally Posted by klundy View Post
    Thanks again John for your long hours of effort.Kevin
    I realize you installed flash, but this is still 100% a flash issue. That screen embeds a .swf (Shockwave flash file) Something with the flash install is not working somewhere. Try installing with Internet explorer, even completely removing it and try installing again.... Each machine reacts differently with flash, so its unfortunately a bit of trial and error.
    My Fiero Build Thread
  3. #373
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    I have it mostly working myself. anyone have the XM-radio working? if so did they have to do anything special?
    MobileRam
    www.XionElectronics.com
    **MY NEW STORE** Come Visit
  4. #374
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    Thanks alot john for all the hard work you put into version 3.0, I really like the new ilists and the color themes.
    I have one major problem tho...version 3.0 seems to be missing the library search function i love so much on version 2.5 Did you purposely leave that the library search out on this version or is there some kind of settings to turn it back on? I've been playing with it for an hour and i still can't figure it out. Any help is appreciated.
    TIA.
  5. #375
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    He burried it on the search button as the hold down cmd, but don't get too used to it being there in the next release, which will have my Media plugin doing all that...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #376
    Jan 2008
    I dont understand it, i just installed xp pro and now when i click on manage playlists, RR freezes up and i have to ctrl alt del. Can someone help
  7. #377
    Apr 2005
    Queens, NYC
    ahh i see. thanks mucho. Even though im currently 99% satisfy with the library search, im really looking forward to your media plugin. Keep up the good work dood!
  8. #378
    Jan 2007
    Looks great, can't wait to fiddle around with it!
    Are you 2x? Because I want to integrate you from 10 to 13!
  9. #379
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by JohnWPB View Post
    The templates for the XM / Sirius favorites is in the DigitalFX 3.0/Helper Files/ folder. The icons are in Road Runner/XM. Just drag the icons onto the template in Photoshop or your favorite image folder. You will need to edit the XM Favorites skin to change the channel numbers to match your stations.
    NOTE: The XM icons are in PNG format, and just renamed to .gif so RR will display them. If you attempt to load them into Photoshop, it will complain that the file can not be loaded, as it things it is a gif, and cant load it as such. Road Runner is smart enough to look at the header in the image file to determine what kind of image it actually is, believe it or not, Photoshop is not that smart
    The templates are actually out of date, it looks like they're for the 2.5 version of DFX. I went and pulled together my own photoshop file with the 3.0 version.
    Enjoy.
    Edit: I noticed after the fact that there was some bad blending with lighter backgrounds, so I tweaked that so it looks less half-arsed. Also, you will need to modify the XM_Favorite.skin, there are issues with the selection areas, and of course you need to set your channels as well.
    Attached Files Attached Files
  10. #380
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Very Nice! Everything stable over here, every time I play with DFX I discover something new about it! The only request I have is a release in binary form. I really don't like the installer at all, maybe its just me, but I find the installer to actually complicate the install of a skin. I use non-standard paths so these types of skins packaged with an installer I just extract to a temp directory and start working from there.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
