Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3851
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    since the last release of DFX, new commands have been added in rr to go to the next and prev of whatever is playing EA: next video, song, radio station all with one button command. I will get this all sorted out before the next release.
    My Fiero Build Thread
  2. #3852
    Nov 2004
    St Louis
    Quote Originally Posted by vicky_obee View Post
    Hi John
    Is this a flaw or is it supposed to be like this only.....
    I have 12 stations in my Radio page... ( using Si Labs )..
    While in this page i can use the Forward/reverse buttons to go to next or previous tuned radio station ( i guess it works like this ... Fine )
    but when i am on the main menu screen ( while the radio still playing ) the Forward / reverse buttons dont work to change the channel....
    Should this also not work like in the radio page
    Thanx
    vicky
    I've run into this type issue on several skins. The easiest way to fix it is get a multi-file editor (WildEdit is what I use) and search and replace all NEXT and PREV commands to RRNEXT and RRPREV in all your .skin files.
  3. #3853
    Oct 2007
    NY
    any ideas why i cant switch out the clock?? when i go change it to the lexus logo, it freezes up and i have to shut it down via task manager.
  4. #3854
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by JohnWPB View Post
    Hmmm no way that I can think of.... The easiest way would be to create a sub folder in the skin folder with the different variations of the image. Then whatever it is that is supposed to change the contents of the text file, just do a file copy instead to the correct name to be displayed by the file indicator.
    Something like:
    copy <Skinpath>/Indicators/IndicaorStatusOn.png <SkinPath>indicator.png.
    When an image that is displayed with the file indicator changes on the drive, it is updated instantly in RR.
    I am in Canada for the next few days, if nothing else, when I get back I could make a small AutoIt script or something to possibly do something like this....
    John, I think I donīt make myself clear, I want to show the content of a TXT file in the skin, and I want this content to be updated every time I press a button in the skin.
    (I will have a txt with a percent value that changes every time I press a button, and I want to see this value on the screen)...
    Do you think that will be easy to understand if I put here a image of the screen/skin?? (cause my english sucks... hehehe)
    thanks
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  5. #3855
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Like how much is in this txt file? One line, serveral lines/pages? Would just be easier if we knew what your trying to do..
    Like do you want to display the whole txt file in one big label or ???
    Thinking that a screen cap might show what your not telling us..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #3856
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    As soon as I back to home I will printscreen the skin...
    but I just want to show a few characters in a small label, like: "50% - 08%"
  7. #3857
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by hailrazer View Post
    No it's not a 100% fix. That's what we're saying.
    A lot of times the lower left start icon is still there even after using the "hide task bar" option.
    Ok, i was able to look at RR config and find it. Open RRConfig, go to General and Page 1. Check mark the Taskbar under the hide section. This will work, as it completely turns off the task bar 100%. I was having the same problem here on a new install I am working on, and remembered where that setting is, and now when I go to GPS or to Video, there is no task bar anywhere in sight
  8. #3858
    Mar 2009
    netStumbler
    can help my to embedding netStumbler on roadrunner
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    As promissed, attached the image of the mixer skin. Please see inside the red circles the text that should be captured from a txt.
    The buttons above and below the skulls controls my front/rear speakers, and every time that I press those buttons, the text must be refreshed...
    all this trouble because I canīt figure out how to use the sliders with my system (the name used by the system is analog and analog:2, and the slider just donīt work with that...)
    (I am using the skulls to show the level, the guitars change the color acording to the level of the sound)
    anyway, what I need right now is a way to show the value of the speaker level (txt file) in the marked place...
  10. #3860
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
