Like Tree1Likes
Thread: DigitalFX 4.0
  1. #3861
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Quote Originally Posted by Enforcer View Post
    What does the txt file look like?
    WYSIWYG, I just put the percent value inside the txt, example:
    level1.txt = 50% level2.txt = 10% (after "=" is the content)
    how are you changing the levels of those two lines?
    I create an Autohotkey to increase/decrease the value of the mixer channels and use the "RUN" command to call the script when i press the buttons
    How are you creating the txt file?
    the same script create/overwrite the txt after I press the button
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  2. #3862
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Any Ideas?
  3. #3863
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    My next Q would be Y are U using a sep app to control the lines? Should all be able to be done in RR code.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #3864
    Oct 2007
    NY
    Quote Originally Posted by LiCelsior View Post
    any ideas why i cant switch out the clock?? when i go change it to the lexus logo, it freezes up and i have to shut it down via task manager.
    bump........................
  5. #3865
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by marteline View Post
    Any Ideas?
    Yeah.
    Have the script send a command to RR which sets a variable and then writes that variable to the skin.ini rather than your own text file.
    then read that variable for your label.
  6. #3866
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    I canīt manage to make the RR control my rear/front lines of the mixer...
    I donīt know why... everything else works fine, like master, balance, wave, but the rear and front lines not...
    the name of the controls are ANALOG and ANALOG:2... I try the sliders... no joy...
  7. #3867
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Yeah.
    enlight me... pls
  8. #3868
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    You have to first chose the correct menu layout - have you done that?
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  9. #3869
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Using the SkinTool, does "SETVOL;ANALOG;46" or SETVOL;ANALOG:2;25" work?
    Are those the exact line names as found at the top of the RR debug log?
    Or C&P the lines that look like this...
    8/25/2009 10:52:02 PM: Source: xxxxxxx
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #3870
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
