Check your start menu for DigitalFX and in there choose "Fix Flash Problem" before you start RR. This is a small script that manually changes the menu layout in case you are stuck with a 3D logo, and unable to change it due to High CPU.
My Fiero Build Thread
I am unfamiliar with RR debug log... but I am pretty sure that those are the exact name, I check it with a software and also use those names on the scripts, and it works like a charm... (all other mixer controls have the same name in RR and in my software, so, I think that the rear and front also have the same names)
I will try SETVOL tonight , cause I just try change the sliders in the DFX skin, but I donīt think that this is the case...
I will let you know as soon as I try. (and thanks for all your help man, donīt give up on me)
Engineering: Where the rubber meets the road!
RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
I am using the Autohotkey and each button close of the skull have a particular script.
This bellow one reduces the rear speakers in 5%, save the final value of the rear level in a txt file and changes the skull image acording to this value
all other buttons works like this, just change the soundset to increase or to control other channel (front)
-------------------------------------------------script start---------
script removed to reduce the size of the thread... If someone want it... just send me a message... :-)
-------------------------------------------------script end---------
i'm gonna use my big voice for this: LOL
My 2010/DFX5.0 (whichever comes first) ultimate suggestion for probably the best skin ever!!! running under the best front end ever!!! is this:
John, Blue, et al:
We all know that the new release will bring plenty of excitement and joy to the hearts of thousands. We can expect hundreds of questions, solutions, comments and praises. We all know that 50% of the members aren't too keen on the search utility or maybe some (including myself) really don't have the kind of faith on that "search" utilitiy finding all our needs...
Would you and the crew behind you consider starting a DFX forum? I know, I know, it's an ingenious idea and one that may never have crossed your mind (LOL - being full of it right now and JK) but with it's own sub-forum, you can create sticky threads for all features of DFX5.0 e.g.:
- buttons
- GPS
- Video
- HD RADIO
- XM/SIRIUS
- Embedded Apps
- TV
- Youtube
- Button Editor
- Skin Editor
- radio
- Bluetooth
- etc. etc.
At first it may seem daunting in having to monitor manage several sub-categories. Initially it is. After it's implemented, the reward of organizing such discussions will begin to appear - including:
- easy navigation for the users and adminisrators
- direct focused attention on specific areas
- opportunity to delegate and distribute the strength in skills in a balanced manner
- probably the most important: A future release of DFX that may be more stable than anyone could ever imagine. Possible consideration for commercial use (did i say that outloud?) due to such stability/reliability.
Please consider this from someone who has admired the work of the people mentioned here (among others) and my intentions and vision is to see them succeed beyond their imaginations.
Thank you,
Javier :: afterdigital :: @2009AD ::
vote for me![]()
CTS 05, Mobile Information Center...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
5.6" Screen (overhead) w/reverse capability
Finished Project
Car Hacking
WorkBlog
Video
The next version will have its own new thread. This is just way too absurdly HUGE of a thread now and trying to find solutions to any/all issues that users have had is a fairly daunting task, and that's even using good search terms and not under a noob status..
But John will have to add or give his opinion on that subject. That would ultimately be a GREAT solution and make it easy after the initial starting of it to both keep progress posted along with being able to find a solution to a issue that has been previously posted.
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
In the RRConfig, General > Pg 4 on the right side, Debugging option. Tick the box and save, if you have RR going already, close it and restart it. After its started, look in the RR folder for the "debug.txt" file. The top part of the log is all the info regarding all the comp's mixer lines. The ones you want to pay attn to is the ones that have the "SOURCE:" in them as those names after the source are what you need to use in RR for it to know and be able to adjust the right line.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Blue,
here is the debug log.
9/5/2009 6:27:28 AM: Source: SPDIF=&H1001/8
9/5/2009 6:27:28 AM: GetLineControl Failed: 401
9/5/2009 6:27:28 AM: Can't Open Source
9/5/2009 6:27:28 AM: Source: Front Green In=&H100A/9
9/5/2009 6:27:28 AM: Source: Line Volume=&H1002/10
9/5/2009 6:27:28 AM: Source: Front Pink In=&H100A/11
9/5/2009 6:27:28 AM: Source: Mic Volume=&H1003/12
9/5/2009 6:27:28 AM: Source: CD Volume=&H1005/13
9/5/2009 6:27:28 AM: Source: PC Beep=&H100A/14
9/5/2009 6:27:28 AM: Source: PC Speaker=&H1008/15
9/5/2009 6:27:28 AM: No Mute for Source
9/5/2009 6:27:29 AM: PLAYER: Winamp Version: 2.05
Can you now edit your post and remove all that debug.txt, thanks.
Lines that You want are...
Your two lines your looking for should be "Front Green In" & "Front Pink In".
Your btn cmds for the -/+ buttons should be
B00,x,y,w,h,"VOL+;Front Green In"
B00,x,y,w,h,"VOL+;Front Pink In"
B00,x,y,w,h,"VOL-;Front Green In"
B00,x,y,w,h,"VOL-;Front Pink In"
Your label codes should be
L00,x,y,w,h,r,g,b,font name,pt,"VOL:Front Green In"
L00,x,y,w,h,r,g,b,font name,pt,"VOL:Front Pink In"
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
