Page 39 of 557 FirstFirst ... 29303132333435363738394041424344454647484989139539 ... LastLast
Results 381 to 390 of 5570
Thread: DigitalFX 4.0
  1. #381
    Jun 2002
    Virginia
    Quote Originally Posted by chuckctv View Post
    I have it mostly working myself. anyone have the XM-radio working? if so did they have to do anything special?
    I have XM working. There is nothing to do other than ordinary setup in RRConfig. If it was working before there's no reason why it won't work with the new version of the skin.
  2. #382
    Dec 2006
    Quote Originally Posted by JohnWPB View Post
    I realize you installed flash, but this is still 100% a flash issue. That screen embeds a .swf (Shockwave flash file) Something with the flash install is not working somewhere. Try installing with Internet explorer, even completely removing it and try installing again.... Each machine reacts differently with flash, so its unfortunately a bit of trial and error.
    Ok, two installs of flash later and it is working. I removed the first, then tried the link in the FAQ a second time. That didn't work. So I removed it again. Then I just installed directly from Adobe and now it works.
    Looking good!
  3. #383
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by blk02si View Post
    Very Nice! Everything stable over here, every time I play with DFX I discover something new about it! The only request I have is a release in binary form. I really don't like the installer at all, maybe its just me, but I find the installer to actually complicate the install of a skin. I use non-standard paths so these types of skins packaged with an installer I just extract to a temp directory and start working from there.
  4. #384
    Dec 2006
    BROOKLYN NY
    i installed xport its workin good but am getting a error message from RR when am playin music...
  5. #385
    Low Bitrate fixinstuff's Avatar
    Jul 2005
    Illinios
    Quote Originally Posted by utd09bry View Post
    I have mine working.. did you download and place the zipped package of files from mitch? should have gone in the RR folder called HD Radio
    Let me know what all you did and maybe I can help you out. It's flippin sweet once you get it running
    Ok, done this several times, I click on HD Radio, I can hear the reciever turn on and back off. The skin never opens, RR freezes up, and I have to reboot and start all over. Even before I connected the reciever, RR froze up. It also freezes up with the radio skin. The same download opens on the test computer.
    Fixinstuff
    Been there, done that, replaced it with a smartphone.
    Scott AFB, IL
  6. #386
    Low Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    When i click next or previous on dfx3.0 or 2.5 it only rewinds or forwards the video or movie. How do i get preview and next to work? please help. just pm me and thanks in advance
  7. #387
    Low Bitrate nhra no 2's Avatar
    Aug 2006
    Aurora, IL
    Color quality keeps resetting to 8-bit on main menu???
    I have just installed DXF-3.0, and I love it. Great job to all... I wasplayin around with setting my screen resolution to 1024x768 the other day, and my 7" Lilliput didn't like it. So I changed it back to 800x600. Now every time when I start RR w/ DXF-3.0 something is resetting the color quality back to 8-bit. If I min RR and reset it in display properties, all the screens eccept the main screen will display 16-bit or 32-bit. Is there a setting in the ini file, or something in winamp that might be causing this. This has me really stumped. And when I changed the screen res I also set it in RR config, I have also reset it to 800x600. This will not solve my problem either.
  8. #388
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    so the new library search feature is buried within the regular search button...is there anyway to remap the search button to the library button? cuz i really dont need the regular search and holding it down for the library search is a problem for me cuz it doesnt play nice with my touch screen. It only works half the times...
    Sorry for this noob question, this is probably an easy fix for most of y'all but im having a tough time figuring it out.
    thanks
    //EDIT:
    nvm, i figured it out from looking at the digital fx 2.5 audio_browser.skin
    I changed this line in Audio_Browser.skin for version 3.0
    B08,595,164,100,89,"SEARCHFILES",@Load;Audio_Searc h.skin@
    into
    B08,595,164,100,89,"Load;Audio_Search.skin",
    Everything seems to be working fine. I'm a happy man!
  9. #389
    Apr 2005
    Queens, NYC
    BTW i just wanna point out that iList doesnt work in library search. Not sure if that was intentional or not...
  10. #390
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by fixinstuff View Post
    Don't know if I understood what you meant by "same download opens on the test computer."
    But also, it freezes even without the radio connected to the pc? Are you using RRConfig to setup your radio settings? Set everything to HD Radio?
    When I hit HD Radio, I do get a slight pause as the unit clicks on but no more than a few seconds. Also when going back to the Music screen to kick-off the radio there is another pause... unit clicks off... mutes Line-in... then Music screen loads.
    I would double check your config settings next if you already have all the right files... in rr.ini set HDRadioport=3 (or whatever port you are using), radiomode=8 (for HDRadio)
    Just trying to cover all bases. It seemed really simple in my setup so it may be a small bug on your end
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
